Body Crack
Old Nov 1, 2009 | 10:08 AM
absaraka's Avatar
Car: 1987 Camaro
Engine: 383
Axle/Gears: Working on that
Body Crack
This question has probably been asked before but here goes. I have an 87 Camaro with a body crack starting to appear at the back of the drip rail above the drivers side door. Does anyone have experience with this and any suggestions for a reliable fix?
Old Nov 1, 2009 | 10:24 AM
Stephen's Avatar
Car: 87 GTA
Re: Body Crack
That is the typical crack that appears, because of the unibody flexing over the years.
About the only way to fix & prevent its return, is the have the body checked for straightness, have it fixed if it has tweaked over the years, then install subframe connecters.
You could simply instal subframe connectors, but in my opinion, I would wonder if the unibody has flexed out of TRUE alignment over the years.
Old Nov 1, 2009 | 11:00 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Body Crack
Welcome to TGO. The problem is common given the flex in f-bodies. A good set of SFC's will generally eliminate the problem. A search will provide more info should you need it.
JamesC
Old Nov 1, 2009 | 11:01 AM
absaraka's Avatar
Car: 1987 Camaro
Engine: 383
Re: Body Crack
Thanks Stephen. I was already planning on adding strut suports as well as subframe connectors. The car has never neen wrecked, no rust, and has been well cared for, but may be out of true from 150000 miles of driving. Your suggestion is a good one, and I will have the unibody checked prior to prepping for paint.
Old Nov 1, 2009 | 11:04 AM
absaraka's Avatar
Car: 1987 Camaro
Engine: 383
Re: Body Crack
Thanks James. Already planned on SFC's and strut supports. Can this be welded as a repair for paint or will the crack just reappear?
Old Nov 1, 2009 | 01:06 PM
toomany's Avatar
Re: Body Crack
Welding is the way to fix the cracks. I take a tiny drill bit and drill the end of the crack, then use a small ball peen hammer to make a dent over the entire crack. Weld in, grind down and skim coat with filler. Never had an issue with them reappearing.
I'd put some SFC's in before doing this tough.
Old Nov 1, 2009 | 01:40 PM
absaraka's Avatar
Car: 1987 Camaro
Engine: 383
Re: Body Crack
Thanks Toomany. I will add this to the grocery list. Looks like I have some minor work in front of me.
Old Nov 2, 2009 | 02:32 AM
crug75hid's Avatar
Re: Body Crack
if its a crack and not scratch then only 2 ways out
either replace the door
or weld the crack, then some filing and some paint touch. cheaper way actually
Old Nov 2, 2009 | 06:14 AM
JamesC's Avatar
Re: Body Crack
either replace the door...
This stress crack appears behind the drip rail over the window on the body.
JamesC
Old Nov 2, 2009 | 03:14 PM
hedberg667's Avatar
Car: 1989 GTA
Engine: 5.7 350
Re: Body Crack
Just like everyone else said grab some SFCs. i don't have a crack yet but i would rather take precautions before i get one.
Frozer!!!
Jan 19, 2024 04:55 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
neekolzun
Aug 24, 2015 04:59 PM
LittleFranks
Aug 20, 2015 03:55 PM
