Hood fitting out of the box?
Old Nov 22, 2009 | 07:38 PM
MADMAXGTA's Avatar
Car: 89 TTA
I just got this "Duraflex"ram air hood and It dont quite fit out of the box,Is this normal? will a body shop be able to work this out?
http://img72.imageshack.us/i/hood1003.jpg/
Old Nov 22, 2009 | 07:53 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Hood fitting out of the box?
I would send it back. That looks like crap.
Old Nov 22, 2009 | 08:59 PM
Pocket's Avatar
Car: 91 Trans Am
A body shop can fix minor flaws with fitment
Thats a massive warp thatll never come out. Send it back
Old Nov 23, 2009 | 01:01 AM
MADMAXGTA's Avatar
Car: 89 TTA
yea Im pissed
Old Nov 23, 2009 | 10:23 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
man, that stinks.....paying good money..and having fitment issues like that!
Old Nov 23, 2009 | 11:52 AM
MADMAXGTA's Avatar
Car: 89 TTA
yes I agree..hind sight being 20/20 I would have went with harwood..and still might,Im having a body shop come take a look,Ill keep you posted,yea..what a bummer,all cause I wanted a holley stealth ram..
Old Nov 23, 2009 | 11:54 AM
1Aauto's Avatar
Former Sponsor
Are the hood struts making it bow up like that on you?
Old Nov 23, 2009 | 12:26 PM
MADMAXGTA's Avatar
Car: 89 TTA
I just had a collision tech stop by and we found that its hitting the radiator shroud not allowing it to close completely,thus could be fix by cutting out a small section under the hood,It seems to contour and not be warped,just not setting all the way down. and I also was wondering if the hood struts have some thing to do with this,however it is definatly hitting the radiator shroud.
Old Nov 23, 2009 | 12:30 PM
MADMAXGTA's Avatar
Car: 89 TTA
This is wher its hitting,and i removed the raidator shoud just to check and it still hits...http://img692.imageshack.us/i/hood1005.jpg/
Old Nov 23, 2009 | 01:06 PM
1Aauto's Avatar
Former Sponsor
If the hood struts are still attached.I'd undo them and see how it fits.Start from square 1.
If you can get eh middle to relax the front will push forward.
Old Nov 23, 2009 | 02:28 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
As to Harwood hoods, have installed two of them on third gens.
Still had to do a little trimming to install.
Know yours is a Bird and mine an Iroc but in both cases I installed
there was a notice not to use the stock struts as could be a problem
like that. Recommended to use the struts from a earlier fiberglass hood
for our cars. Never researched it as I made up some nice looking straps
I use at shows to keep hood up.
Can't even tell there there.
Did have to trim back of hood before painting to clear wipers.
Nothing is ever completely hassle free when it comes to custom parts.
( At least in my case).
What I like is after after slight prep and painting can't even tell the hood
is fiberglass, NO waves like so many others have unless (Heavy) into prep
work.
HTH
Later
Old Sep 2, 2010 | 09:20 AM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
back from the grave! what was the out come with this hood?
Frozer!!!
Jan 19, 2024 04:55 PM
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Dialed_In
Aug 20, 2015 01:45 PM
bryan623
Aug 10, 2015 11:33 AM
