door weatherstripping check this out
Old Jan 8, 2010 | 07:28 PM
dirtpoor1's Avatar
Car: 84 z28
Engine: 305 vin H
Transmission: auto
Has anyone purchased this door weatherstripping? It says it has steel inserts. New premium version with steel inserts. Only $100 for both doors. GM is about 400 for both doors. Don't mind paying for quality and peace of mind but 300 extra, holy cow!
http://www.camarocentral.com/product_p/wea-979.htm
Old Jan 8, 2010 | 10:33 PM
84RIceEater's Avatar
Car: 84 Camaro. 90 integra
Engine: LG4, 1.6 (402hp)
Transmission: 700r4, JDM ITR w/ kaaz LSD
Re: door weatherstripping check this out
Old Jan 8, 2010 | 11:21 PM
p100ki's Avatar
Originally Posted by 84RIceEater
Very helpful post, nice to see you took time out of your day to actually help someone with a question they had. Kudos to you fine sir.
Old Jan 8, 2010 | 11:33 PM
oscarsrs's Avatar
Car: 91 RS/ QX56/Altima 3.5 SE
Transmission: AUTO
Axle/Gears: ?
Look who's talking .
And on the strips they sound to good to be true, if any body has them post pics and thoughts.
Old Jan 8, 2010 | 11:59 PM
p100ki's Avatar
Excellent jab there dude but i have no personal experience with the product the op asked about, just like you and the fine gentleman i quoted originally.
Old Jan 24, 2010 | 07:39 PM
dirtpoor1's Avatar
Car: 84 z28
Engine: 305 vin H
Transmission: auto
I just installed these today on my nephews 84 Z28. I was impressed with the metal inserts on the ends where the screws go. The stripping that I had installed just 3 years ago ( can't remember brand) did not have any. The old stripping kept pulling out of the plastic retainers on bottom of door, the rubber around the holes split. This new molding seemed to have much better plastic retainers as far as the rubber side is concerned. I tried to pull one out but couldn't. But here is my concern. They pushed way to easy into the door for my taste. I'm afraid I will have trouble with them pulling out of the door. The plastic retainer pins have very short ribs on them. They all lined up good with the exception of the very first one on the driver door. It was off about 1/4" and was already pulled quite tight so I opted to just drill a new hole. I tried 1/64" smaller but really had trouble pushing in so I drilled out to original size, 7/32 if memory serves. The rubber is fimer than what I had and doors shut a little harder but maybe that's a good thing so rubber won't split. I guess only time will tell. $115 for both doors. Best price I could find was 370 for GM.
Old Jan 24, 2010 | 07:44 PM
Aldakoopa's Avatar
Car: 1987 Trans Am
Engine: 305 4 bbl
Transmission: The kind that goes "kachunk" in 1st
You can buy better clips for $10 tops if it worries you that much. Not that hard to change either, all you need is a pair of pliers.
Old Feb 10, 2010 | 10:42 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
Transmission: 700r4 stock
I just posted a ? about this just a minute ago and now I found this. Is this the stripping that starts close the door handle and then travels around/under the door mine is messed up about where the striker latch is right where the sail panel and door meet. on both doors how does that happen?
Old Feb 10, 2010 | 10:46 AM
dirtpoor1's Avatar
Car: 84 z28
Engine: 305 vin H
Transmission: auto
yes it is.
Old Feb 10, 2010 | 11:01 AM
rs owner's Avatar
Car: 89 rs black
Engine: 305 v8 tbi
I just checked out camaro central and they have everything that I need for less than 1/2 the price of the gm stuff. see now that is why I come to thirdgen ya'll are the best
thank you
could you do me a favor and look in the engine swap forum and tell me if I'm getting ripped on the 350 short block assem.
Old Feb 10, 2010 | 11:14 AM
mister_hudson's Avatar
Car: '92 Z28 Convertible
Engine: 305ci TPI
Transmission: 700R4 shifted
Axle/Gears: 2.73 (for now)
Agreed - Camaro Central has some good prices on some usefull pieces. I have yet to order anything from them but it sounds like they are on the up & up...
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Apr 9, 2018 03:00 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
