clean shaved
Old 01-11-2010, 11:46 PM
1fastrock's Avatar
Car: 89 Camaro IROC
Engine: 383 Stroker
Transmission: turbo 400
clean shaved
Hey guys im painting my car and want to get rid of all of the badges because they are not accurate any way. But here is my problem I want to get rid of the plaques on the ground effects but i don't want to just fill it with bondo because i don't want it to ever just fall out. Has anyone ever done this before and if so how did you do it?
Thanks in advance
Old 01-12-2010, 12:23 AM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Re: clean shaved
Lots of MIG welding I guess. The trick is to block the back of the holes with a piece of copper sheet taped on there temporary.
The weld slag wont stick to the copper and the copper will keep unwanted oxygen from creeping in and burning through making the holes bigger.
That's the only "right" way,,,,,,,,,,,,,,,,,,, unless you have a TIG.
Old 01-12-2010, 12:31 PM
UDAMON's Avatar
Car: Mazda Protege5
Re: clean shaved
lol... mig welding the ground effects..
anyways. look for a flexible parts filler at an autobody store. there are countless products out there that you can use for areas like that. proper prep and it will last a lifetime.
Old 01-12-2010, 01:20 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: clean shaved
you could always try to find a spare piece of gfx, cut it to fit the emblem opening, and use an epoxy to attach the two. that way you're not using a ton of filler
Old 01-12-2010, 02:02 PM
Car: 1989 IROC
Engine: 305TPI
Re: clean shaved
oh
Thought you were talking about trimming the gfx and everything.. I had a car where they filled in the badges with bondo on the sides and nose but it all came out pretty easy.
Kind of ghetto really....
Old 01-13-2010, 09:05 AM
89lxjimmustang's Avatar
Car: 1988 Iroc-Z
Engine: 5.7
Axle/Gears: 3:73
Re: clean shaved
I Might be interested in all of your emblems? What color? Pictures please? and how much shipped to indiana zip 47138?
gta892000
08-11-2019 11:16 AM
sailtexas186548
02-17-2017 03:07 PM
350 IROC-Z
Camaros Wanted
12-18-2015 03:58 PM
Thirdgen89GTA
10-19-2015 09:27 AM
3GZJerry
LSX and LTX Parts
10-14-2015 05:17 PM
Quick Reply: clean shaved
