problem removing bolts from frame
Old Feb 16, 2010 | 12:56 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
I need to remove the 3 bolts that hold the track bar brace to the frame, so that I can remove the gas tank to replace the fule pump. They do not want to give in. Ive tried the liquid wrench stuff, & Ive been fighting with the bolts for two days.
any special trick to remove them?
Old Feb 16, 2010 | 01:39 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: problem removing bolts from frame
Got access to air tools?
JamesC
Old Feb 16, 2010 | 02:43 PM
Alexcoqui's Avatar
Car: Trans Am "GTA"
not in my garage.
Old Feb 16, 2010 | 02:46 PM
89fireeagle's Avatar
Car: 89 firebird 83 t/a
Engine: 305 tbi
try hittin the top of the bolt with a hammer that might help
Old Feb 16, 2010 | 02:59 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
I delt with a lot of these problems with my car when taking it all apart. Best thing that worked for me was spraying WD-40 or PB Blaster or any other lubricant under the head of the bolts and letting it soak for like 30 mins. Then I used a breaker bar - you need the long arm to give a greater moment to break these things loose. And if you have to hit the end of the bar with a hammer a few times to try and break the bolt loose like an impact gun does.
Old Feb 16, 2010 | 03:05 PM
DacMan's Avatar
Ever heard of a breaker bar? It might be a good option, just take your 1/2 inch drive ratchet and mate it to whatever socket you need for the bolts, then take a long pipe preferably 3 foot or more, that is big enough to fit around the handle of the ratchet and slide it over the ratchet. Then turn, the extra leverage will pull those bolts right off, you may have to jack you car up a little to get the clearance, and you might have to use an extension on the ratchet to get enough room to pull on the bar, but they will defiantly either come out or break a head off. Something to keep in mind is that if you don't want to snap the head off a bolt, then put one hand on the extension or socket to support the pressure from the turning from snapping the head off. Also arokroil is a penetrating lubricant that is priceless in situations with stubborn bolts, it's the best penetrating available.
Good Luck, DacMan
Old Feb 16, 2010 | 03:35 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Heat it up, and keep spraying/soaking with PB Blaster. They'll come loose. I've had to soak bolts for hours, but they came out, which we know is better than stripping or breaking it off. Then when loosening just do it slowly, if it feels like its getting to easy too quick, you may be twisting the bolt off in itself in which I have done. I got excited doing it too (half shafts for a 300zx), I said yes, yes yes, its...****!!!
Let us know.
Edit: I love TGO, in the time it took me to write this, 3 responses showed up. Nice guys, nice.
Old Feb 16, 2010 | 03:53 PM
DacMan's Avatar
Let us know.
I know it, SomeGuy25thZ beat me to the punch while I was posting... lol.
Old Feb 16, 2010 | 05:40 PM
Car: 1992 z28
Haha, I type very fast ...
Old Feb 16, 2010 | 06:11 PM
DacMan's Avatar
lol ^^^Stealin' My Thunder!!!
Old Feb 16, 2010 | 09:33 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Yeh my pump went out and my firebird came from up north and replacing the pump was worse then a bad dream I had to dril out most of the bolts and re tap them
Old Feb 16, 2010 | 09:43 PM
knight123's Avatar
Car: 1988 Firebird Formula
Engine: 5.7 TPI
Axle/Gears: 3.27 posi 9 bolt
I did the same last month on mine - every bolt broke from the 3 in the brace - to the panhard etc. what a mess. I used cans of PB blaster before I tried to take them off. Then on the last one tapping it I broke the tap in it. I was being real carefull and thought it was getting tight and said to myself it's got one turn left and bink! Good thing I was laying on the floor already as my head did not have far to fall. ..and cause real damage! Take your time and if they break just resign yourself to the fact that some bolts just won't come out.
Old Feb 17, 2010 | 07:22 AM
JamesC's Avatar
If you're dropping the tank, I assume (never having dropped one) that the brace will have to be entirely removed. If so, you may find that the bolt on the pass side is even more of a challenge, as the bolt probably will have seized to the sleeve. I tried everything under the sun last summer and still failed.
JamesC
Old Feb 17, 2010 | 12:04 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Heat, heat and more heat. I soaked mine with deep creep or whatever and heated them up with a MAP gas torch (yellow cylinder from the hardware store) til they were cherry red and they came off easily. Heat is your best friend when it comes to rusty bolts. Oh and a good impact wrench helps too!
Frozer!!!
Jan 19, 2024 04:55 PM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Eric-86sc
Apr 3, 2016 03:52 PM
LittleFranks
Aug 20, 2015 03:55 PM
3rdgenparts
Aug 8, 2015 07:09 PM
