Questions!!
Old Feb 27, 2010 | 04:18 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
Questions!!
1. How to adjust door windows.
2. how to adjust t-top windows to make them tighter
3. how to adjust hatch so it looks flush with the sidewing
4. aluminum bumpers? will they fit?
Old Feb 27, 2010 | 10:30 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: Questions!!
1 Make sure that it is the glass and not the door out of alien if it is the glass then you can take the door panel off and there are adjustments on top of the door that will move the glass in or out and at the bottom of the door there are 2 other adjustments they are stops if you roll the glass all the way down you will see them that will move the glass up or down one on the front and on at the back
2 I dont know of any adjustment for T tops you may need new rubber?
3 If the hatch is to high then you can remove the trim panel on the rear body panel and adjust the latch down to fit
4 I am not sure about the bumper are you thinking of thr rebar that is behind the rubber cover
Old Feb 23, 2016 | 02:44 PM
Bjerime01's Avatar
Car: Firebird
Engine: 5.0 TPI
Re: Questions!!
Need to know how to make hatch alien with roof line and rear of car. Mine is sitting beyond the rear by a inch at least. Still closes good just out bad by looking at rear end of car.
Old Feb 23, 2016 | 04:44 PM
Engine: LQ4 ls 6.0
Re: Questions!!
If you look at the roof and the glass you will see the hinge there are bolts on the inside lossen them then move the hatch back and re tighten the bolts i think there a torx
Old Feb 23, 2016 | 07:49 PM
Bjerime01's Avatar
Car: Firebird
Engine: 5.0 TPI
Re: Questions!!
Thanks Mirror Image I will try that. Will I have to remove hatch shocks?
Old Feb 23, 2016 | 07:51 PM
Engine: LQ4 ls 6.0
Re: Questions!!
It makes it easy but not necessary
Old Feb 23, 2016 | 07:52 PM
Bjerime01's Avatar
Car: Firebird
Engine: 5.0 TPI
Re: Questions!!
Ok thanks
Old Feb 23, 2016 | 11:20 PM
fokeyman's Avatar
Car: 89 IROC
Engine: l98 350 TPI
Axle/Gears: 373s
Re: Questions!!
Also https://www.thirdgen.org/hatchalign/ for hatch aleinment.
lol alein, you guys are killing me
"alein
Instructive plural form of ale.
(dated) Genitive plural form of ale."
Old Feb 24, 2016 | 11:35 AM
broke91firebird's Avatar
Car: 1991 Pontiac Firebird convertible
Engine: 3.1 soon to be 3.4/3100
Axle/Gears: original gears, for now
Re: Questions!!
To answer the bumper question, I read on here somewhere that aluminum Firebird bars will work. HOWEVER the Firebirds and Camaros have different shapes to their bumpers and are not interchangeable.
Old Feb 24, 2016 | 11:50 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Re: Questions!!
As mentioned, check the weatherstripping before touching anything, it's not very often these move out of adjustment.
Here are some images of the T-Top retainers so you can see that they are adjustable.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
