how to remove body from frame???
what is required to take a thirdgen off the frame (89 RS)? I notice there are lots of off-frames on this site. Nobody ever says how they did it, I'm sure no 2 ppl do it the same. anyone?
Car: 87 GTA
Re: how to remove body from frame???
Nobody does it, because there is no frame. 3rd gens are Unibody construction. Meaning that shaped sheetmetal acts as the "frame". The body essentially is the "frame".
There is a subframe up front, that the front suspension partially attaches to & the engines mounts on, but that's it.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There's a subframe in the back too, but both front and rear subframes are welded in.
Car: 87 GTA
Not really. The rear is welded in, yes. But the front subframe easily unbolts.
You might be thinking of what runs along each side of the tranny, but those aren't quite a front subframe.
Engine: 383 Carb
Transmission: 4L60
Those are the front subframe, and they're welded in. You're thinking of the K member, it's the only part that unbolts.
From everything I've heard the 3rd and 4th gen front subframes are welded to the body like Apeiron said but on 1st and 2nd gen f-bodys you could unbolt the front subframe from the body. My question is why do you want to remove it? Is there unrepairable damage if so it probably isn't worth putting a new one on.
Car: 87 GTA
Engine: 383 Carb
Transmission: 4L60
It's not what I want to call it, it's what it is. The rails aren't just the part on either side of the transmission, they're continuous from the bumper mounts on the frame horns at the front, through the fenders, over the strut mounts, and then down the sides of the transmission.
The K member isn't part of the subframe, they're common features on full-framed cars as well.
Car: '92 Z28 Convertible
Engine: 305ci TPI
Transmission: 700R4 shifted
Axle/Gears: 2.73 (for now)
Just like everyone else said - they are not frames in the traditional sense. There is a lot you can remove but after unbolting everything you are not going to have that traditional frame. I suggest picking up a GM service manual - that will show you how to get to the spot you want to.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
thanx everyone,
with your info and a bit of homework I found out what I needed to know. My mechanic told me I have frame damage, never thought these things had a frame...
Anyway... looks like a few cracks. is it worth fixing? I HAVE SOOOOO MANY NEW PARTS!!!
1992 Trans Am
May 10, 2023 07:19 PM
