how to peel pinstriping off car?
Old Mar 22, 2010 | 02:02 PM
dudeman's Avatar
Car: 87 firebird
hey, i have a yellow pinstripe around my whole car which looks hideous, is there an easy way to peel it off??
Old Mar 22, 2010 | 07:59 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: how to peel pinstriping off car?
i have used a heat gun / hair drier before with good results . start slow with heat and non-scratching scraper . a plastic/hard rubber spreader would work . if it's a very narrow stripe even your finger nail would work . you may find un-faded paint under stripe . good luck .
Old Mar 22, 2010 | 08:04 PM
campin1983's Avatar
Car: 1984 Camaro 'Vert
Goo Gone works wonders for any adhesive that's left behind after you peel the vinyl itself off.
Old Mar 22, 2010 | 08:07 PM
1fastrock's Avatar
Car: 89 Camaro IROC
Engine: 383 Stroker
Transmission: turbo 400
They also make a remover than you can pick up at your parts store. I'ts called wood grain remover or something like that. All you do is spray it on and scrape it off with a rubber scraper. It worked really well when I took mine off.. hope that helps
Old Mar 23, 2010 | 02:11 PM
dudeman's Avatar
Car: 87 firebird
cool, thanks for the help!!
Old Mar 24, 2010 | 01:49 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
find a auto body store and tell the you want a pin stripe removal wheel, chuck it in your drill and go to town
Old Mar 24, 2010 | 01:54 AM
84z .....'s Avatar
Car: Blue 84 z28/Cyber 2010ss/rs
Engine: Dart headed, 12:1 355- 510/530 cam
Transmission: TKO 600 Lakewood Bell
Axle/Gears: Richmond 410 Spooled
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
