Do I need hood pins?
Old Mar 24, 2010 | 05:09 PM
sethteef's Avatar
Car: 88 firebird
I am going to buy a bolt on 4in cowl hood and was wondering if I need to put in hood pins.
Old Mar 24, 2010 | 05:45 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Re: Do I need hood pins?
I would serious consider it if your putting on a fiberglass hood. I did for my IROC, and I feel alot safer now.
Old Mar 24, 2010 | 08:27 PM
evol's Avatar
Car: 1991 Z28 camaro
Hey i actually just picked up a 91 z28 and I just noticed that it has the exact same hood as yours does Americanmouse. When you where going down the road it it look like it lifted up in front and kinda sway back and forth?
What kind did you use?
Old Mar 24, 2010 | 08:35 PM
Stephen's Avatar
Car: 87 GTA
Way more fiberglassed hoods cars running around without pins, than cars with pins. So I wouldn't worry about it, if you have one from a reputable manufacturer.
I've run them with & with. With pins, was only because my wife wanted pins on her Camaro, not because she needed them.
Old Mar 24, 2010 | 08:42 PM
Car: 1988 IROC-Z28
My hood is from Hawks, and I noticed when I'm going over 45mph it starts to make a lot of sound air wise that is. So I put the hood pins in to be safe.
Old Mar 24, 2010 | 09:20 PM
sethteef's Avatar
Car: 88 firebird
Alright thanks guys. I ordered the hood today but have to wait for them to finish making it.
Old Mar 24, 2010 | 09:23 PM
americanmuscle3's Avatar
Car: 83 z28
i talked to a few manufacturers like glasstek and vfn and they both recommend the use of pins
Old Mar 24, 2010 | 10:07 PM
Firebat's Avatar
I'd install them just to reduce the chances of the following:
-Getting in a car accident
-Causing someone else to get in a car accident
-Having to buy a new windshield
-Having to buy another hood
Yes, you can go without hood pins on a fiberglass hood just like you can drive a car with bald tires. Most of the time you will probably be ok but its a little risky.
Old Mar 24, 2010 | 10:14 PM
Stephen's Avatar
Car: 87 GTA
That is a 100% unfair comparison. As I said above....There are WAY, WAY, WAY more fiberglass hood cars running (rarely see a fiberglass hooded truck with pins, unless it is a "race" truck, or wants to be) around perfectly fine without hood pins, than with hood pins.
Bald tires are automatically unsafe on anything but a good paved road. Add any gravel or water & you very much risk an off-road excursion.
Old Apr 17, 2010 | 09:18 AM
xxx3man`'s Avatar
Car: 89 Iroc-z
Engine: 5.7 lt
Axle/Gears: 9 bolt
i had a fiberglass hood and it flew off because of no hood pins. so i would buy them and use them for fiberglass $500 is way to much to have to replace
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
mr z28
Exterior Parts for Sale
Dec 14, 2015 05:14 PM
IROCTheHouse
Oct 26, 2015 02:35 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
