Any bolts that I missed?
Old Apr 12, 2010 | 09:59 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
So I am removing the passenger side fender and the damm thing won't come off.
Im I missing something, is it something with the antenna? I removed the top screws that run along with the hood, the 4 connected to the front bumper with the single to the body and the 1 under the gfx.
I try pulling it apart and its still being held by something near the bottom right of the fender. Anything I missed?
Quick help would be sweet
Old Apr 12, 2010 | 10:37 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
Transmission: stock BW 5 spd.
Axle/Gears: stock 3.42
Re: Any bolts that I missed?
unscrew the antenna at the base, unscrew the flat piec under it with a pair of channel locks, pull the plastic thing under that off,, then straight down from the antenna is a big bolt 13mm I think it's usually bent to where you can't get to it because this is also a jack point.... other than that I think you got them all.
there's a bracket in the front, did you get that, it's a V shape.
Old Apr 12, 2010 | 10:59 PM
Carlos773's Avatar
Straight down the antenna? You mean the 1 bolt that secures under where the gfx goes onto the fender? By the way is it only 1? I see another but it looks sorta plastic made and does not seem to be something that comes off but I will take a look at it closely again.
Yea theres 2 actually the support that is under the front area and then the other that you cans see when you remove the front bumper.
Old Apr 12, 2010 | 11:08 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
yeah it'd be right under the gfx, but like I said it's usually bent to where you can't see it too good, you might also have to unscrew some bolts from the gfx itself, I don't know much about the front ends of GTA's/85-> TA's the only one I took apart, the front was smashed clear to the wheel openings.
Old Apr 15, 2010 | 11:05 PM
Carlos773's Avatar
Yep that was the story there, someone had previously jacked the car from there bending the bolt where I cant see it. Fender is off now. Thanks for the help!
Old Apr 15, 2010 | 11:09 PM
maroon85's Avatar
Car: '85 Firebird
Engine: 2.8 V6
no problem.
hectre13
Dec 11, 2023 08:14 AM
Eric-86sc
Apr 3, 2016 03:52 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Bryan F
Aug 27, 2015 07:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
