fixing cracked ground effects?
Old Apr 26, 2010 | 07:52 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Hey guys, well the front ground effects (the super rare parts) on my 91 Trans Am 'vert have a bunch of cracks in them so I was wondering what would be the best way to fix em. I was thinking of gluing then throwing bondo on the cracks to smooth them out but I'm afraid that the bondo itself will crack since the plastic is more flexible. Here's a couple pics of what I'm deal with.
Thanks!
Old Apr 26, 2010 | 07:59 PM
rick121's Avatar
Car: 91 Camaro RS
Engine: 3.1 liter
Axle/Gears: positrac off an 83 T/A
Re: fixing cracked ground effects?
i epoxied mine and then used fiberglass resin over it to smooth it out. the fiberglass doesnt crack when it bends in the wind. worked great for my camaro. till I met the back end of a truck.
Old Apr 26, 2010 | 08:43 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Most auto parts stores(Autozone/Advance/Pepboys/etc) have bumper repair epoxy in the body work section. Its a 2-part epoxy that comes in a syringe you mix up and put on the bumper/ground effects like bondo to patch cracks and holes.
Old Apr 26, 2010 | 08:46 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
sand the area 40 or 80 grit then....
Old Apr 26, 2010 | 08:52 PM
Engine: LB9
Does that need anything on top of it (other than paint) or will it sand smooth?
Old Apr 26, 2010 | 09:06 PM
FueledSoul's Avatar
Im not sure what your asking but that fillers waterproof and doesn't suck or hold in moisture so you dont have to prim and top coat right away
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I tried both bondo/glass and epoxy resin. Both WILL....I repeat...WILL sheer off with an impact with a high curb, etc. I then purchased a product called duramix from 3M(check TCP global or 3M itself). It's a plastic weld that is a bit on the pricey side but the repair is stronger than the spoiler itself. You should be able to youtube it for a demo. The ground effects and front/rear bumpers are plastic....not glass. good luck
Old Apr 26, 2010 | 09:09 PM
FueledSoul's Avatar
The ground effects are glass, the front and rear bumpers are urethane based
Old Apr 26, 2010 | 09:30 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
My front lip is cracked a bit, I have some fiberglass repair kit and see how it goes if not try some things this thread mentioned.
Old Apr 26, 2010 | 10:06 PM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
can't be.....I sanded both parts....they're the same material on my 91. I searched and searched and searched. I repaired the spoiler with duramix and then purposedly hit the same curb that sheered off my epoxy repair. The duramix held up
Old Apr 26, 2010 | 10:54 PM
Justin89Formy's Avatar
Car: 89 formula 350
Engine: ls1 magnuson tvs2300 supercharger
Axle/Gears: 4.11 Dana 44!
a body shop can plastic weld that stuff
Old Apr 26, 2010 | 11:09 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
DO NOT use this it will crack, its made for filling purposes not structural.... is the part plastic or fiberglas?
if its urethane (plastic) use this: http://www.emisupply.com/catalog/nor...term=NOR-04617
and this to reinforce it from the back http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 works the same as the one u get at autobody store but cheaper
i'll xplain the process if you go with this, and you don't have to coat it b/c its urethane
Old Apr 26, 2010 | 11:10 PM
juanillox8's Avatar
Car: TOO MANY
fillers are porous , specially bondo, its better to put primer right away
Old Apr 26, 2010 | 11:12 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I agree I have used duramix and 3M they work ok but I weld all plactic parts with my welder
Old Apr 26, 2010 | 11:14 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
you might be interested in this thread
https://www.thirdgen.org/forums/auto...cks-fixed.html
Old Apr 27, 2010 | 06:12 AM
FueledSoul's Avatar
the front spoiler is urethane based. i read the title of the thread and looked at the pics and jumped into posting before knowing it was the front spoiler he was talking about. the fiberglass filler will work but like menchend above hit a curb it will crack
Frozer!!!
Jan 19, 2024 04:55 PM
3rdgenparts
Exterior Parts for Sale
26
Apr 7, 2016 11:21 AM
mikey8494
Aug 22, 2015 07:57 PM
GVMV
Aug 16, 2015 07:08 PM
92firebirdchris
Aug 14, 2015 11:56 AM
