Factory steps for installing new T-tops.
Old May 2, 2010 | 08:10 PM
Brandon J. Watt's Avatar
Car: 1992 Chevrolet Camaro RS
Engine: 3.1 Litre V-6
Transmission: Automatic
Does anyone have the factory process of installing replacement t-tops. I've switched to glass ones on my '92 RS. I've tranfered the weatherstriping from the Lexan ones to the glass ones but am getting slight water leakage. I think I may have adjusted the snug down too little or in the wrong order.
Old May 2, 2010 | 09:21 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Factory steps for installing new T-tops.
{Subscribed}
Old May 4, 2010 | 12:50 PM
So i went to the thread you sent me and got "subscribed" I don't know what this means.
Old May 4, 2010 | 02:12 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
It means that the user t-top havoc doesn't know the answer to your question. By replying to your thread, he is now "subscribed", which basically means he'll get notified when someone else replies to your thread and he'll check in with the hopes of getting the same answer you're looking for. There is an option to simply subscribe to a thread without replying to it under the "thread tools" menu, but most people don't know about it or don't care to use it and reply to the thread instead just to be subscribed.
Old May 4, 2010 | 03:05 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
As far as i know, the weather stripping only should go in really one way, and the rest of the adjustment is in the pin holders on either side. If the leak is towards the back, adjust the adjuster down in the back and vice versa for the front if thats what leaks. Shouldn't be all that difficult as long as the weather stripping wasn't damaged in the process. Try and see if there is any obvious gaps, then maybe the weather stripping should be moved, but if not, it's probably in the adjusters as long as you used enough weatherstripping adhesive to install onto the glass tops.
Vintageracer
Jan 10, 2020 05:33 PM
mdtoren
Aug 23, 2015 12:52 PM
crazynights
Aug 21, 2015 06:53 AM
mdtoren
Aug 16, 2015 05:45 PM
fonzie85
Aug 13, 2015 11:50 AM
