underside paint
underside paint
I'm at a point where I have to touch-up or refinish in it's entirerty the underside of my 86 Sport Coupe.
I like the idea of the factory paint however I also like the preserving quality of a good rust paint.
Let's see pictures of some detailed chassis.
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Re: underside paint
Why not use some kind of under coating? Dont they use salt on the roads up there? Or I have heard of some useing spray on truck bed liner and have seen on the internet that you can also have it in almost any color.
Re: underside paint
I always use bedliner:
Axle/Gears: Stock
Re: underside paint
just what the bedliner cost, 1 large can and I have a bunch left.
Re: underside paint
It DOES look clean.
I assume you had removed all the little bits and pieces prior to paint?
The only drawback that I can imagine with the bedliner is that it's thickness would prevent full seating of bolt on components like the trans crossmember and lower control arms.
Or was that not an issue?
Re: underside paint
Yes, completely stripped, all the underbody goop removed w/ kerosine, then a light scotchbrite w/ degreaser/paint prep and then sprayed on the bedliner.
The thickness is no issue, I had everything off, and everything goes back together just fine.
Re: underside paint
Yes but if the climate is like it is here that won't stay like that for long.
Sure looks awesome & clean. Nice!!!
Hotrodboba400
Dec 10, 2019 07:07 PM
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
tyeo098
Nov 30, 2015 06:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
