floor pan drain plugs
Old Jun 3, 2010 | 10:13 PM
T1m3_Sh1ft3r's Avatar
Car: 1986 Trans Am
Transmission: TH700R4
Axle/Gears: IDK yet
Well i have decided to go start working on the body of my bird and went to town pulling carpet and plastics. and i noticed that there are a few oval holes in the floor where i would suspect that plugs should cover them. i know i need to seal these holes but can i just wield sin sheet metal over them or is there a place that sells these for our cars, i looked around and found second gen f body plugs but not third. and should i use paint stripper to cover the floors with that por15 stuff? or can i paint over the existing paint?
Old Jun 3, 2010 | 10:30 PM
Blown84Bird's Avatar
Car: 84 firebird, 85 transam
Engine: 350 SBC Or 7.07 Tonys,305stock
Transmission: Big Ugly, 700r4
Axle/Gears: 4th gen rear disk 3.42 lsd,9 bolt
Re: floor pan drain plugs
Check hawks might have the plugs or go to the bone yard and pull some out. Also you could just weld a cover over the hole. And paint.is up to you if you don't have any rust just paint over what is there.
Old Jun 3, 2010 | 10:43 PM
Car: 1986 Trans Am
Axle/Gears: IDK yet
ok cool so i just need to grind down the area i want to wield and get some sheet metal. as for the por15 i just wanted to know if i could paint over the already existing paint on the floor so i can prevent more rust
Old Jun 3, 2010 | 10:44 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
check the bottom of your carpet, may have stuck to it, also for the floors? POR-15! yes, por15 will go over existing paint, just hit it with marine clean first!
Old Jun 3, 2010 | 10:50 PM
Yup grind and weld. Since you have rust por15 sounds like a good idea. You can use a wire wheel to remove any loose stuff
Old Jun 4, 2010 | 01:31 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
The JY in Poulsbo has lots of third gens, I'm sure most of them still have the plugs. Should only cost a few $.
If that sticky stuff is still on the floor that they used to seal the plugs, I have found that heat makes it much easier to remove.
Old Jun 4, 2010 | 01:57 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
I never understood the purpose of the drain plugs...
They put a hole in your floor, but it's covered with that sealer "sheet" so it can't drain anything anyway
Old Jun 4, 2010 | 02:10 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Its mainly for the factory when they run the car thru the huge vats of liquid it will all drain out quickly and therefore dry faster
Old Jun 4, 2010 | 02:23 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I've always wondered what those were for, it's good to finally know. But now I have a new question: why do they put the cars through huge vats of liquid?
Old Jun 4, 2010 | 03:55 PM
I believe one is an acid to remove all oils and weld slag, the next kills the acid, the third is self etching primer.
Old Jun 5, 2010 | 09:59 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
i cut out patches and welded all mine up...
Old Feb 14, 2011 | 05:41 PM
chevman24's Avatar
Car: 88 and 02 Camaro's
Engine: L96 (LS) and LS-1
Transmission: auto, 6 speed
Axle/Gears: 3.42 gears for both
This is good to know. I have a big rust spot near one of my drain plugs and want to just weld it up. So that is what i will do!
gixxer92
Sep 1, 2015 04:32 PM
Justin92GTA
Aug 27, 2015 11:16 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Amillionoh7
Aug 7, 2015 01:24 PM
