also need door info
Old Jun 6, 2010 | 10:05 AM
Matt S iroc's Avatar
also need door info
i need to replace the passenger side door.r all f body doors interchangeable?
Old Jun 6, 2010 | 11:02 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: also need door info
Yes. The only difference is in the holes for mounting the ground effects and the way the little black rubber triangle is mounted in the door.
Old Jun 6, 2010 | 11:05 AM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
also the armrest bracket is different
Old Jun 6, 2010 | 11:16 AM
alright.is it a pain to modify the holes to put the body kit on and if i get a different year camaro door will the holes line up right?
Old Jun 6, 2010 | 08:40 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I currently have a door from an 82-84 Camaro on my 92 RS. I didn't have to change anything on it except for that little corner triangle piece. The holes for the ground effects lined up perfectly with the studs on my 92 ground effects.
Juanillox8 - What is different about the armrest brackets? I've had both the original armrest from my car on the door as well as armrests from an 82 and an 86.
Old Jun 6, 2010 | 10:47 PM
juanillox8's Avatar
Car: TOO MANY
this is the pontiac's bracket
and this is the camaro's brackeet
Old Jun 7, 2010 | 07:47 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Thanks for the pics. Never knew they were different between Camaros & Firebirds. Then again, I never tore a Firebird door apart either.
Old Jun 7, 2010 | 06:27 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
ive seen a firebird door on a camaro. The fire bird has a curve to the body work and camaro are flat. the curve above the latch top corner. But if youre going to swap once and paint, it will be eye sore. but it works.
Old Jun 7, 2010 | 08:10 PM
yeah.well ill just buy a camaro door so i dont have to mess with anything else except for the door panel!thanks guys.
Old Jun 7, 2010 | 08:18 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Not all firebirds' armrest brackets are like that. Only the ones with deluxe door panels. 82-84 firebird doors brackets are the same as camaros, and 85-92 firebirds have a small metal bracket riveted to the handle to accept the different handle trim.
Silver Spear
South East Region
18
Dec 4, 2015 09:59 PM
billybob6110
Sep 23, 2015 01:30 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
tsfso59
Exterior Parts Wanted
Sep 9, 2015 09:09 AM
NiG
Sep 7, 2015 11:25 PM
