sliding rear window in notchback?
Old Jun 15, 2010 | 10:30 PM
87bluebird's Avatar
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
i was wondering if it was possible to put a sliding rear window in a notchback? kinda like the ones in a lot of trucks.
can it be done?
has it been done?
should it be done?
how hard would it be to do?
Old Jun 16, 2010 | 09:42 AM
87bluebird's Avatar
Transmission: t56
Re: sliding rear window in notchback?
i was thinking you could take the window frame from an s10 or something like that and cut it down till its the same size as the window in the notchback. then you could get a sheet of plexiglass or lexan and cut out the window pieces and caulk them into the modified window frame.
Old Jun 19, 2010 | 08:32 PM
87bluebird's Avatar
Transmission: t56
i cant believe no one has any thoughts on this.
other than gumby who said that if the window is fairly square it should be cake to do but if the window is rounded like his it would be an expensive pita. are the original gta notch back hatches window square enough? what other brands of notchbacks have a square enough window?
Old Jun 19, 2010 | 09:07 PM
jesusramirez817's Avatar
Car: 1986 trans am
Axle/Gears: non posi : (
i was wanting a notchback for my 86 trans am but i cant really find one. can any one tell me were to find one?, and if so how much do they usally cost? thanks
Old Jun 19, 2010 | 10:32 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
You can find a few for sale or for trade on here now, search.
But I can tell you the factory OEM ones were U-G-L-Y
You can buy then new for $6-8-1,000 shipped.
OEM
Old Jun 20, 2010 | 01:18 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
How about using the mechanism from an Avalanche where they slide down into the back wall so you can fold it down for more room or up for more passengers.
Old Jun 20, 2010 | 01:33 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
No were for it to slide down.
The 2nd thought I had would be make it like an early moon roof, or a van side window, where it has a locking lever that when flipped down, opend it up a few inches, then lock closed to stop weather.
Old Jun 20, 2010 | 05:29 PM
87bluebird's Avatar
Transmission: t56
i think i get what your sayin what way would you tilt the window?
Old Jun 20, 2010 | 05:38 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
out so rain can't get in.
Old Jun 21, 2010 | 01:51 AM
hinged at top and latch at bottom?
Old Jun 21, 2010 | 10:48 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
yea,
Old Jun 21, 2010 | 07:54 PM
Sounds like fun!
Old Jun 22, 2010 | 04:59 PM
87bluebird's Avatar
Transmission: t56
which would be easier or cheaper to do tilt window or sliding? also which would give better airflow?
Old Jun 22, 2010 | 07:47 PM
Tilt for both.
Old Jun 24, 2010 | 08:19 PM
BigKeg's Avatar
Car: 87 Black Irocz28
Transmission: 700r4 shift kit
Axle/Gears: 3:73 richmend axles and eaton gears
I wanted to do this to mine. I even thought that I could use a back window from a Dakota. My dad had a Dakota with a power slide. How ever my notch back has waves on the flat part. I know a guy that dose fiber glass, he said get a different notch back.
Old Jun 24, 2010 | 10:03 PM
BigKeg's Avatar
Old Jun 24, 2010 | 10:55 PM
87bluebird's Avatar
Transmission: t56
what do you mean by "waves on the flat part"?
how close is a dakota's window to the notchbacks?
Old Jun 24, 2010 | 11:52 PM
It would be too wide for the notchback.
Maybe a slider from a 60's - 70's datsun pickup.
Old Jun 25, 2010 | 02:59 AM
BigKeg's Avatar
Never took a tape measure to the Dakota. My dad doesn't even have the the truck anymore. I just thought that it can't be that much bigger than a s10. It's just that the Dakota had a power slide back window.
And as for my notch back..( I will post pics later ) the flat part between the window and spoiler has two dips and when it rains. It makes three lakes. Two on the notch back along the bottom of the window and one in the car. The notch back doesn't even seal right. It leaks more than my t-top. I like The notch back, but who ever put it on just didn't do what I would call a good job. But I liked enough to buy it like that so I will fix it or replace it.
Old Jul 6, 2010 | 07:29 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
brain fart, wonder if you could buy or make a thin but long sliding plastic vent.
Think of like a floor or heat vent. a couple of tabs to push over a tad to open or close a whole bunch of slots.
and I mean small in height, 1-2in but close to full width but not full width.
I think for sealing and strength, just notch the botom of the window for it, but still have 2 sections on each side into the window seal. So the vent isn't holding the bottom of the window in.
mull that one around.......
Old Jul 6, 2010 | 09:03 PM
spade's Avatar
Car: 1989 Mystery Firebird
Engine: 350 FIRST TPI
i would love to do something like this to my notchback.... im even gonna do that pin setup that gumby has
Old Jul 6, 2010 | 09:40 PM
87bluebird's Avatar
Transmission: t56
can you explain this a little more clearly maybe post a pic of what your talking about?
Old Jul 6, 2010 | 10:04 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yea know somthing like this but only 1 small long row near window width.
in that pic the center is a tab, push to the left they all close, to the right open. But nothing so big n bulk or such a wide boarder.
Might be already made. That design is popular in plastic HVAC floor vent covers.
Old Aug 22, 2010 | 01:31 AM
85 ZXX's Avatar
Car: 85 Z28 T-Top 36mm sway & wonderbar
Engine: TPI L98 350 W/85 Vette Stage II ECM
Transmission: W/C T-5, alum drive shaft
Axle/Gears: 9 bolt posi, 3:27, PBR's, BB LS1's
Re: sliding rear window in notch back?
I have a aftermarket notch back and there is no dam to support the window.
Any ideas, suggestions, pictures and information will be greatly appreciated.
Thanks!!!
Old Aug 22, 2010 | 06:15 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Thanks!!!
It wouldn't, the rubber molding holds the window in place.How mine is. the rubber has a channel on each side, one side slips onto the window frame lip, other side the glass slips into.
Also to have any sort of window that opens in the notch the exhaust would have to run out the sides and maybe in front of the rear tire.
Its like a station wagon then [I have one] factory the exhaust runs out the sides so when the rear window is down or even cracked, it won't suck fumes into the car. It would do the same with a notchback if it ran out the back.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Dialed_In
Aug 20, 2015 01:45 PM
