Trans Am Fender on Base Firebird (1986)
Old Jun 22, 2010 | 04:18 PM
Keegancw's Avatar
Does anybody know if Trans Am fenders will fit on a base model firebird of the same year? I ask because I found a couple (http://market.autopartsfair.com/pont...t_type=fenders) that seem to be a decent price, but they are labeled as Trans Am parts.
Also, while I make this post... I was wondering if the same could be said for the hood. I want a hood with some sort of scoop or vents on them (More for looks than function.) Will a hood from a similar year work? Is there a year range that I can look for instead of sticking to the same exact year?
Thanks guys
Old Jun 22, 2010 | 07:50 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
Re: Trans Am Fender on Base Firebird (1986)
85- 89 all interchange no worries. 82 - 84 different nose, 90 - 92 different again.
Old Jun 22, 2010 | 07:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
85-90 are the same, 91-92 are different
Old Jun 22, 2010 | 07:58 PM
Keegancw's Avatar
Thank you very much you guys. Is this the same for any body part, including the hood?
I appreciate the replies. Its helping a ton
Old Jun 22, 2010 | 08:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
most parts will interchange, but the ground effects and bumpers changed over the years, hence the different in fenders, same with the interiors. any hood from 82-92 bird will fit.
Old Jun 22, 2010 | 08:06 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
All 82-92 firebird fenders fit all 82-92 firebirds. Only differences would be whether or not there is a hole for the fender vent, or where the holes are drilled for the ground effects. All 82-92 firebird hoods also fit all 82-92 firebirds.
Old Jun 23, 2010 | 01:35 AM
Thanx for the correction I was a bit tired when I typed that.
Old Jun 23, 2010 | 07:37 PM
windowrattler's Avatar
Car: 92 RS, 89 Formula, 84 Iroc
Engine: Carb 350, TPI 305, TBD
Transmission: T-5, 700r4, TBD
Axle/Gears: 3.42 Posi, 3.08 Posi, Moser 3.73
there are some differences in the headlights also might follow the same year pattern 82-84 85-90 91-92
Old Jun 23, 2010 | 09:44 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
This is the correct answer. ALL of them interchange. There are NO differences except for fender vents or GFX holes.
1992 Trans Am
May 10, 2023 07:19 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
colton_carlson
Mar 8, 2019 12:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
