Body guys need opion on hood
Old Jun 22, 2010 | 05:42 PM
Coyotesa's Avatar
Car: 1987 Trans Am WS6
Engine: 305 tpi
Well after some time of searching for a formula hood i finally found one, but now i am not sure if i just wasted my money. Hoping someone can help me out, I know the pictures are not easy to see but can you tell me if this hood was a lost cause and waste of money. It has a depression on the powerbulge and quite a few dents..possibly some hail damage can this be fixed and can it look good?
-Buddy-
Attached Thumbnails Body guys need opion on hood-circles.jpg   Body guys need opion on hood-img_1396.jpg   Body guys need opion on hood-img_1395.jpg
Old Jun 23, 2010 | 12:35 AM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Re: Body guys need opion on hood
Doesn't look all that bad...How are your body work skills, or were you going to hire it done??? A good body man can fix it right up.
Old Jun 23, 2010 | 07:22 AM
Coyotesa's Avatar
Engine: 305 tpi
Yes i was going to have someone else work on it, i have no body work skills.
Old Jun 23, 2010 | 07:28 AM
DIRTY JERZY's Avatar
Car: 89 formula 350 & 2001 ws6 ta
Engine: 350 tpi & ls1
Transmission: 700r4, t56
Axle/Gears: 9 bolt ? & 10 bolt 3:42
Its not all that complicated just strip it to bare metal, do a skim coat of filler, block sand, primer, paint, clear, wet sand, and buff to shine.
If you do it your self it can be a great learning project. Most body shops will want to blend the color with the fenders, bumper, and doors this can get costly.
Old Jun 23, 2010 | 09:34 AM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
You will need to pop the larger dents out first or you will wind up over coating with filler. The hood is a focal point on a car. Its opened and closed often it may start to spider-crack eventually and you don't want that to happen on a hood.
Pop the dents out and use the least amount of filler as possible.
Old Jun 23, 2010 | 08:13 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
I don't see a problem with it. A bit of pingin' and dingin' along with a bit of filler it should be good as new.
Old Jun 23, 2010 | 08:23 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
The pushed in area looks something that might need some good attention but other spots look good.
Like others said, pop them out as much as you can to use the least amount of filler, and stay away from Bondo. I had similar dents and used a gel hammer my father uses for his carpet work and worked perfectly. It all depends if you want to spend the time on it.
How much did you spend on it? I would assume around $35-$60.
Old Jun 23, 2010 | 08:25 PM
ls1fiend's Avatar
Car: 1985 z28, 1994 Sierra
Engine: 350, 350
Transmission: T-5, 4L60E
You're good to go, bro. Don't let a few pings deter you. And I agree, this would be a good learning project if you decided you wanted to learn.
Old Jun 23, 2010 | 08:54 PM
Coyotesa's Avatar
Engine: 305 tpi
I wish i was cheap, i spent $125 on it, i have been searching for one for awhile and jumped on this one when i found it. The plastic piece on the powerbulge was there and not damaged. It was quite dirty do i didnt see all the damage on it, as someone said before the only spot that really worries me is the powerbulge dent, it pops in and out kinda flimsy.
Thanks for all the advice!
-Buddy-
Old Jun 23, 2010 | 08:59 PM
astrosurfer's Avatar
Car: 84 trans am
Engine: 305 5.0L HO
Transmission: TH350
I wish mines had that little work needed.
I say go for it.
I'll be doing the same thing to a GTA hood here soon.
Old Jun 23, 2010 | 09:02 PM
Carlos773's Avatar
-Buddy-
$125? Eh not a good price but not that bad. I would of def talked the seller down though.
Frozer!!!
Jan 19, 2024 04:55 PM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
LittleFranks
Aug 20, 2015 03:55 PM
Street Lethal
Aug 14, 2015 08:25 PM
bryan623
Aug 10, 2015 11:33 AM
