Rear hatch weatherstripping Q
Old Jun 24, 2010 | 03:53 PM
89RESTO's Avatar
2011 Norwood Gathering
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Axle/Gears: 9 bolt 2:77
I'm installing new hatch weatherstripping and wondered if I should run a bead of sealant around the lip or not? There didn't seem to be any sealant there when I removed the old weatherstripping. Just wondered what others have done.
Old Jun 24, 2010 | 04:11 PM
Raiderfan's Avatar
Car: '92
Re: Rear hatch weatherstripping Q
I was thinking about doing this to mine. It's got a random leak at the top and I have no idea where it's coming from.
Old Jun 24, 2010 | 11:59 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
So how far out of adjustment are your hinges?
Old Jun 25, 2010 | 05:48 AM
Raiderfan's Avatar
Car: '92
Was that for me or 89resto?
Old Jun 25, 2010 | 08:48 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
you shouldn't NEED any sealant due to the design of the seal, but it wouldn't hurt to use a little to help keep it from shifting around or pulling up accidentally.
Old Jun 25, 2010 | 10:00 AM
89RESTO's Avatar
ThirdGen Camaro Rep
Car: 1989 IROC
Engine: 5.7
Thank's 1ADan, I thought I would put a little at each of the four corners for the reason you mentioned and a little at the seam.
Old Jun 25, 2010 | 02:22 PM
for you.
Old Jun 26, 2010 | 07:29 AM
Raiderfan's Avatar
Car: '92
for you.
I didn't think they were out of adjustment. The weatherstripping is not exactly centered, what I mean by that is the seam is not directly in the middle of the licenses plate. The metal trim is a little loose at the top of the glass also, not leaking from there though. I poured water all over the area last weekend and couldn't get it to leak!? I guess I'll check the hinges next.
Old Jun 27, 2010 | 10:02 PM
Jonathan Dyer's Avatar
Car: '83 Berlinetta
Engine: 383 CI
Axle/Gears: 3.73, Eibachs, Tokiko Illuminas,
Permatex has a sealant that never fully dries out - kinda like a sticky gel/grease. It's enough to give a reasonable seal without actually gluing the rubber to the car permanently. If I remember correctly it's blue in color. I've used it on my T-Top rubbers.
Jon
Old Jun 27, 2010 | 10:07 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
if it don't dry, it won't stick.
Use some 100% clear silicone in key places, it won't be stuck for good.
Then spray some wd-40 on a rag and wipe down the hatch area where it sits.
That will keep it from sticking, rubber, plastic n paint safe.
I
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
