Rear Hatch
Old Jul 21, 2010 | 10:38 AM
Josh4036's Avatar
Rear Hatch
Ok so i have a 1991 camaro rs. The problem is that i cant get the back hatch open..I dont have the button or anything and the cable in the back has been cut >. The previous owner just said he never opened it anyway so he didnt care. Is there any possible way to open the hatch so i can atleast get into the hatch so i can put my stereo stuff in.
Old Jul 21, 2010 | 10:42 AM
Stephen's Avatar
Car: 87 GTA
Re: Rear Hatch
You'll have to climb in trough the back seat & hotwire the latch release. Not sure what cable you are referring to, since that implies a manual pull ting like for the hood, and there is no manual pull release for the rear hatch.
Old Jul 21, 2010 | 10:46 AM
Josh4036's Avatar
Re: Rear Hatch
hmm im not sure what that cable is for then. I figured it was a manual release or something like that. How exactly do i hotwire the release hatch?
Old Jul 21, 2010 | 02:21 PM
87bluebird's Avatar
Car: 1987 pontiac firebird
Engine: 6.5 turbo diesel
Transmission: t56
Axle/Gears: Ws6 axle
Re: Rear Hatch
are you talking about the lock cable? is the lock still attached?
Old Jul 21, 2010 | 03:49 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Rear Hatch
There is a small cable that runs from the key lock to the lock on them all.
Gonna be hard to do it from the inside as the plastic stuff has to come out to gain access, and there are 2 screws on top by the lock latch.
Old Jul 22, 2010 | 03:58 PM
Josh4036's Avatar
Re: Rear Hatch
Ya there was a cable that was pulled out and it was cut? i have no idea what the retard that owned before me was trying to do...So is there something i need to do with the cable? i should be able to get the plastic off but what do i do when i do get it off?
Old Jul 22, 2010 | 04:28 PM
Stephen's Avatar
Car: 87 GTA
Re: Rear Hatch
The plastic wraps over the top & goes under the hatch, with 2 screws holding it down PLUS there is a hole in it for the latch to go through & hook to the hatch. No way to get it off, with the hatch closed.
Your pretty much screwed, as far as opening the hatch & saving that plastic. You are going to have to cut through the plastic to reach the cable.
Second thought for Camaros (which you have).....
You might be able to flip your plate down, drill a hole in the sheetmetal big enough to reach something trough. But that depends on where the cable is broke. If it is broken at the key cylinder end, all you need to do is get ahold of the cable & pull, releasing the hatch. If is broken somewhere in the middle, you can do the same thing. If it is broken at the hath latch end? Your screwed & the plastic has to come off.
Not a fun problem!
Old Jul 22, 2010 | 11:23 PM
Josh4036's Avatar
Re: Rear Hatch
ya i was thinking i was screwed but ill take and upload some pictures of the cable and everything so you guys can see how it is..
Old Aug 2, 2010 | 01:20 PM
mfeller's Avatar
Car: 91 Camaro RS/63 Chevy II
Engine: 305 TBI/355" Predator Carbed
Transmission: 5 Spd\T400 w/TBrake
Axle/Gears: Unknown/4.11
Re: Rear Hatch
I don't have a key for my hatch, but the lock cylinder has been removed from the hatch itself so I can open it with a flat screwdriver. My question is: how do you get the lock cylinder out of the plastic sleeve that it sits in so I can take it to a locksmith and have a key cut??
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
