Bad rust hole or what?
Old Aug 7, 2010 | 08:22 PM
Big Cleatus's Avatar
Car: '84 Trans Am
Engine: 350 Carb
Axle/Gears: Stock but subject to change.
I've been sanding down my car to prep for paint and I noticed behind my rear wheel about 1/4 inch diameter rust spot. Started sanding it with 60 grit and discovered it was MUCH larger. Little rust dimples and stuff. Pulled my dremel out to fully attack the rust dimples and popped a little hole. Stuck my finger in the hole and pulled, and this pic is the aftermath. Nasty. I'm in the military and getting relocated to Korea in a few months, so instead of getting a whole new panel I think I'll just bondo it and worry about the new panel when I get back.
Old Aug 8, 2010 | 03:43 PM
Car: '84 Trans Am
Engine: 350 Carb
Re: Bad rust hole or what?
Found this plastic piece just chillin behind the panel when I peeped in the rust hole. No idea what it is or how it got in there.
Old Aug 8, 2010 | 03:54 PM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
Looks like or something similar to a front seat bolt cover. Also is this in the rear quarter? Looks like it. It looks like a simple fix. Most metal shops can probably patch it and grind it or not for you for cheap.
But to answer your question, yea its a bad rust hole, anything to me that has enough corrosion to punch a hole that big, means theres more all over the vehicle.
Old Aug 8, 2010 | 06:28 PM
rideon1200's Avatar
On Probation
Car: 2002 Formula
Engine: 5.7 LS1
Wyoming, USAF? Nice hobby shops overseas, why dont you take it with you, they still ship free?
Old Aug 8, 2010 | 09:01 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
That plastic piece is supposed to hold the tail light harness tight against the tail panel behind the rear trim... I'm going to assume this is the driver's side, right?
Patch panel shouldn't cost you too much. It's finding a decent one that could be a royal pain.
Old Aug 9, 2010 | 04:52 PM
Car: '84 Trans Am
Engine: 350 Carb
Yes it is the drivers side. As far as overseas, they will ship it for free, but I'm going to Korea. I can't take my car. I can't even drive a privately owned vehicle over there. I'll be cruisin in a POS HMMWV for a year. God I hate HMMWV's. They are not made for anyone taller than 5'0". Kinda like the back seat of a third gen.
Frozer!!!
Jan 19, 2024 04:55 PM
hemicudakidd
Aug 31, 2015 06:23 AM
neekolzun
Aug 24, 2015 04:59 PM
LittleFranks
Aug 20, 2015 03:55 PM
