T-Top glass edge material replacement
Old 08-10-2010, 10:57 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Has anyone ever replaced the composiste material that is located just above the drip rail on a t-top glass? My original t-top has this part cracked and I want to replace the chipped piece with another good piece. The problem is what kind of adhesive can I use to glue the piece to the glass?Pictures below show the piece that is chipped, and the piece that I want to take off to replace the chipped one.
Attached Thumbnails T-Top glass edge material replacement-chipped-t-top-edge.jpg   T-Top glass edge material replacement-piece-remove-replace-chipped
Old 08-10-2010, 11:12 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: T-Top glass edge material replacement
Maybe 3rdGenRanch, Hawks, dave mc, or a u-pull-it???
1AAuto is doing the dripseal weatherstrip soon, IDK if that is part of it or not.
I know it's not much, but a lead anyway!
Old 08-10-2010, 11:30 PM
I have 2 pairs of t tops. One pair is my original small pin and the other is from a RS which have the small pin incased with a large plastic spring loaded pin.
Old 08-10-2010, 11:32 PM
And the drip seal is one piece which is either hard plastic or flimsy rubber. But I dont care about that right now. My issue is the hard plastic/composite edge that is glued to the glass.
Old 08-11-2010, 12:12 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Why not just use the other set of T-tops? They are interchangeable.
Old 08-11-2010, 02:01 PM
Yes they are and I have done just that. But I noticed that the glass towards the back end pops up a lot and it doesnt create a tight seal. The gap is large enough to make a tiny howling sound while driving.
Old 08-11-2010, 02:23 PM
Former Sponsor
1Aauto's Avatar
We now have the rubber ones for sale.I tossed an Ad down into the vendor section for you guys.
I'm not sure who might have that other piece for you.
Old 08-11-2010, 03:29 PM
Car: 1992 RS
Engine: Carbed 350
"O I C" said the blind man. Oh well, it was a thought.
Have you tried adjusting the pinholes on the car side? There is a tad of adjustment in there, just have to take the screw out of the pillar plastic and pull it back out of the way some, and there are 2 bolts holding the pinholes in place, you dan loosen and adjust these a tad.
Old 08-11-2010, 03:44 PM
Im gonna try that right now. Ill be back in about 15 minutes.
Old 08-11-2010, 04:23 PM
It worked!!!! Now all I gotta do is buy the a new dripseal for $55 a pair from our very own vendor (Thanks 1ATony ).
Attached Thumbnails T-Top glass edge material replacement-1.jpg   T-Top glass edge material replacement-2.jpg   T-Top glass edge material replacement-3.jpg
Old 08-11-2010, 05:30 PM
Car: 1992 RS
Engine: Carbed 350
Cool. I'm glad it did, and happy to see the pic - I can point others to it - many folks don't know they are adjustable. And actually I forgot how much adjustment there really is in there.
Let me (and the rest of us) know how Tony's drip seals work out. I need to get a pair myself, but at the moment cash is too tight so Santa is gonna need to know about them!
Old 08-11-2010, 06:57 PM
Im low on cash too bro. But Im trying to sell my old college books. As soon as I get the money and make a purchase, I'll take pictures when I get the strips but Im not even sure when I'll get em. But Ill will post them up when I buy them.
Old 08-12-2010, 07:52 AM
Former Sponsor
1Aauto's Avatar
No problem guys.
Old 08-12-2010, 11:05 AM
da.slyboy's Avatar
Car: 84 frankenstein Z28
Also to help answer the posters original question.....no company (that I'm aware off) make the piece you are referring to. The only replacement is a different set of t-tops
Old 08-12-2010, 09:22 PM
Yup. I heard that they where adjustable but I didnt know that the can be so much room for play. I do see that there is one drawback of this type of adjustment piece though. You can only penetrate the plastic piece with a new hole so many times before the piece is bad. Im gonna hit the junkyard to find more of these pieces just incase.
Old 08-12-2010, 09:28 PM
to reply to this reply, Im not looking for a new replacement part to buy. My chief question was what kind of glue can I use to glue down the trim that broke off the edge of the T-Top glass. I already have 2 complete sets. Im thinking of buying just one driverside from the jumkyard so that I can remove the trim (from the broken t-top glass) and replace the cracked trim with a used trim.
Old 08-11-2011, 03:38 PM
FINALLY!!!! I just recieved my brand new hard plastic Drip Edge Weather Strip. I bought it for only $54.95 on Ebay. Cant wait to install it later.
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
gta90
09-15-2015 04:00 PM
Golfvette
08-24-2015 06:35 PM
qz6lwp
08-20-2015 08:10 PM
BrianI
08-09-2015 11:52 AM
Quick Reply: T-Top glass edge material replacement
