Battery tray
Old Oct 2, 2010 | 03:29 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
Battery tray
Hey guys, I want to repaint my battery tray and the area next to it. The tray itself is starting to rust, and the area next to it has paint flaking off. I was wondering if there was a way to remove it so I can paint the whole thing top and bottom? I was wondering too wtf that ball thing with the line coming out of it was that dropped down when I removed the screws on the front of the battery tray.. Thanks guys!
Old Oct 2, 2010 | 06:24 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: Battery tray
The ball thing is a vacuum reservoir. Gives your heater control and cruise control (on some models) a place to draw vacuum from when the engine vacuum is low.
As far as I know the battery tray is welded on so removing it would be a problem. But you could drill out the spot welds and break it loose to remove it if whats underneath really warants going thru that much work. But then the process of welding it back on would undo much of the paintwork you did. Not impossible but ... difficult.
Old Oct 2, 2010 | 11:16 PM
BigBadGTA's Avatar
Engine: 350TPI
Axle/Gears: 3:27
Re: Battery tray
Thank you for replying! I actually just cleaned off as much rust as I could, primed over the remaining rust, and painted it. It turned out really good! Its weird because my car is rust free, but the battery holder, and the bracket under the air filter were covered in surface rust and looked terrible. Now that they are nice and black again, my engine bay looks new! I did have a hell of a time trying to mount that vacuum ball back by myself.. thanks again!
Old Oct 3, 2010 | 11:54 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Battery tray
thats quite normal, battery acid will do that.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
