Rear Tail Light Assembly Question--key for hatch too short?
Old Oct 6, 2010 | 10:59 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
Some time in the past, the previous owner of my 84 T/A put in a tail light section from an 88 GTA along with the front bumber and ground effects. The problem this creates is that the key cylinder to the rear hatch is recessed and I can't get the key to turn (The key goes in but the key gets stuck in the "hole"...basically it's not long enough. It's never been a problem because I've got the power hatch lock release but if that ever goes out, I'm screwed. Does anyone have an idea on how to remedy this? can I get a lock cylinder from an 88?
Old Oct 8, 2010 | 06:12 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Re: Rear Tail Light Assembly Question--key for hatch too short?
So nobody else has this problem?
Old Oct 8, 2010 | 06:45 AM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
Simple ... lock cylinders are different length ... did this to my 84 and replaced the lock cylinder as well as it protrudes another 1/4 - 1/2 inch (can't remember how much).
Old Oct 8, 2010 | 08:55 AM
Ozz1967's Avatar
Car: 1984 Trans Am
So you replaced it with a lock cylinder from the later model?
Old Oct 8, 2010 | 08:58 AM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
Correct, at the time I changed all lock cylinders so just got a kit for a later model 3rd Gen ... 85 or 86 and later as they use the "taller" lock cylinder back there besides the height it's identical.
Old Oct 8, 2010 | 09:00 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Will my original key work or will I have to get another one? I'd hate to have 2, one for the doors and one for the hatch.
Old Oct 8, 2010 | 09:02 AM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
That was one reason I changed all the locks at the same time ... maybe you can get the cylinder coded for your key but not sure you just have to ask when you buy the cylinder
Old Oct 8, 2010 | 09:10 AM
Ozz1967's Avatar
Car: 1984 Trans Am
I'll check with classic industries or year one about getting some new ones.
Frozer!!!
Jan 19, 2024 04:55 PM
LittleFranks
Aug 20, 2015 03:55 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Omega
Aug 10, 2015 12:46 PM
NBrehm
Exterior Parts for Sale
Aug 5, 2015 08:19 PM
