hatch problem
Old Oct 20, 2010 | 09:52 PM
xsupermann69x's Avatar
Car: 1991 Chevy Camaro RS
Engine: V6 3.1L
Transmission: automatic
hatch problem
alright sooo my hatch motor decided to take a crap on me soo i disconnected it and tried to like move the motor down so that the hatch would close all the way and the latch wouldnt even hook on to the hatch. so i moved it back to where it did but when i tried it.... it would latch..... so i went and got me a brand new motor and latch to put on and im still having the problem of it not latching on to the hatch but if i just take the assembly and latch it on to the hatch without it being attached to the car it will latch but when i put it on the car and try and shut it..... it would latch.... have tried adjusting multiple times. so i latched it on to the hatch then shut the hatch and crawled into my hatch and bolted it to the frame and then opened it and tried to shut it again and it wouldnt work....... what is wrong?
Old Oct 21, 2010 | 01:03 PM
Engine: V6 3.1L
Re: hatch problem
any idea guys?
Old Oct 21, 2010 | 01:36 PM
camaromike222's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: Stock 305 TBI, LT1 soon.
Transmission: V6 NWC T5 by choice
Axle/Gears: Zexel Torsen LSD with 3.23's
Re: hatch problem
A mechanic I took my car to when my fuel pump was giving out slammed the hatch down and broke the teeth on the gears in the motor assembly. He didn't know it pulled it down on its own. So, what I did is disconnect it and had to keep adjust the motor little by little till I could just "slightly slam" the hatch down and it would lock. I went through your same dilemma, though. But trust me, there is a sweet spot. Just keep adjusting the sliding motor assembly till it's right.
Old Oct 21, 2010 | 01:40 PM
Engine: V6 3.1L
Re: hatch problem
but the motor does work. its brand new everything
Old Oct 21, 2010 | 01:47 PM
Re: hatch problem
You've tried adjusting it side to side? so that the latch hook actually engages?
Old Oct 23, 2010 | 10:29 AM
Engine: V6 3.1L
Re: hatch problem
yes i have moved it like 100000000000 times......
Old Oct 23, 2010 | 03:43 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: hatch problem
So om I reading this right, the motor isn't working?
Old Oct 23, 2010 | 04:56 PM
Engine: V6 3.1L
Re: hatch problem
no its a brand new latch and motor the motor works.
Old Oct 24, 2010 | 07:10 AM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: hatch problem
Get someone to shut the hatch while you're inside. Check that the latch is hitting the middle of the striker. If it hits on the edge, well it won't be able to "reach" around the striker.
Old Oct 27, 2010 | 08:28 PM
1piece@atime's Avatar
Car: 86 T/A
Engine: 5.0 TPI
Re: hatch problem
Did you get it figured out?
Sometimes the switch on the latch will stop the motor before it has gone thru a full up down cycle. Have you checked the switch to see if it's working properly? Hold the little flipper switch arm down with your finger until the motor draws the latch all the way down and then release it and see if the latch comes back up.
Street Lethal
Apr 30, 2019 12:14 PM
hydrolic144
Sep 8, 2015 06:55 PM
2012sergen11
Interior Parts Wanted
Sep 7, 2015 11:37 AM
neekolzun
Aug 24, 2015 04:59 PM
madsv1000
Aug 20, 2015 06:45 AM
