question about....
Old Nov 9, 2010 | 05:09 PM
batsibf's Avatar
Car: 1986 Firebird
Engine: 3.4L Swap is done
Axle/Gears: Stock
question about....
hey all,
I bought this 1986 firebird, and I have had problems getting the hood to close. Looking through pictures I noticed my frount looks different. can some one tell me if the fount end is the right one for this car???
http://southeastwheelsevents.com/pho...1?context=user
here is aline of my car trying to get the pic to load on here
Old Nov 12, 2010 | 09:42 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Re: question about....
It looks like an early front. Some better pics would help, so we could see what is going on.
I dig the snowflakes.
Old Nov 12, 2010 | 09:55 PM
batsibf's Avatar
Car: 1986 Firebird
Axle/Gears: Stock
what would you like in pics and the previous owner trashed them of the four only one is worth anything.
the latch is hitting behind the hole, and everything looks like it lines up right. if you hold the latch you can close it and it looks like it should.
Old Nov 14, 2010 | 07:08 PM
steve87ta's Avatar
Engine: 461,305TB
Does the hood fit good other than the latching mech?
You can shim the latch a little, front to back.
A heck of a lot of things can mess this up. A pic of what it is doing or where it is hitting may be a place to start.
Old Nov 15, 2010 | 02:06 AM
batsibf's Avatar
Car: 1986 Firebird
Axle/Gears: Stock
Ok I'll get some after I get off work, other than the latch the hood fits fine.
Old Nov 17, 2010 | 01:18 PM
batsibf's Avatar
Car: 1986 Firebird
Axle/Gears: Stock
ok sorry about taking so long to get this up but here they are:
the first is where the latch is hitting when closing and the second is what it looks like closed and a better pic of the frount
Attached Thumbnails question about....-img_2676.jpg   question about....-img_2677.jpg
Old Nov 19, 2010 | 09:50 PM
batsibf's Avatar
Car: 1986 Firebird
Axle/Gears: Stock
any ideas here guys???
Old Nov 19, 2010 | 09:59 PM
mightymaro94's Avatar
did you try shimming the latch front to back as suggested above?... hood does appear to fit correctly from the pic you posted tho
Old Nov 19, 2010 | 10:21 PM
tylercamaro's Avatar
Car: 91 GTA, 73 Z28
Engine: 355, 6.0L
Transmission: TH350, 4L80E
Axle/Gears: 3.42, 3.73
maybe just a dumb idea, just maybe those little rubber stopper thingys on each side, and holding it back possibly?
Old Nov 20, 2010 | 10:16 AM
batsibf's Avatar
Car: 1986 Firebird
Axle/Gears: Stock
Haven't shined it yet look at doing it and The back would have to be raise about 2 inches just to make it fit, I wanted to see any other ideas because I want everything to look stock
Old Nov 25, 2010 | 09:29 PM
steve87ta's Avatar
Engine: 461,305TB
It looks like the front nose is down some on the pass side-but that would not make the latch do what it does.
There is a panel that the safety latch hooks into. It is hard to see with it all together, but it attaches to the core support and has a triangular brace coming up from the bottom. This is the part that you see the hood latch is mounted to and the spring sits in a little cup stamped in to it. There is a hole in it that the safety latch or lever (in your first pic) goes into. I believe this is hitting the angle of the hook.
If you can correct the lever or ramp of the hole you should be able to close the hood with out using your hand on the lever to move it.
It is possible that the hook and or hole is worn and bent. This could be why it does not shut with out a little "help".
It should be easy enough to fix. HTH
Sorry about that late reply-I have not had much time for "board gossip" lately.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
