hatch struts drive me nuts
Old Nov 15, 2010 | 02:57 PM
wastelander88's Avatar
Car: 91 Z28-L98/G92
Engine: 5.7 TPI jasper remanufactured
Axle/Gears: 3:73
hi im new here.i just bought my first camaro a 91 z28 350 tpi.i had to adjust the hatch wing but now i cant get the hatch struts back on.there alot stronger than i thought. i am very mechanicly inclined but keep in my this is my first camaro and ive only had it 2 days.still getting familar with it.any help would be greatly appreciated
Old Nov 15, 2010 | 03:35 PM
AmorgetRS's Avatar
Re: hatch struts drive me nuts
Why can't you get them back on? What is stopping you?
Old Nov 15, 2010 | 03:36 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
yeah, there pretty straight forward. Hatch is heavier than hell but straight forward nonetheless...
maybe you need to compress the struts to where the mounts are?
more info needed...
Old Nov 15, 2010 | 03:47 PM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
You'll need to lift the hatch up, and install the struts at their extended length
If you're trying to compress the struts and install them from inside the vehicle with the hatch closed... Well maybe it's possible, but you're more of a man than me then.
If that's not the problem, not sure how to help you
Old Nov 15, 2010 | 03:52 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
use some 2x4's to hold it up...idk..lol..
or just have some freinds hold it
Old Nov 15, 2010 | 03:54 PM
AmorgetRS's Avatar
+1 to a friend or someone else holding the hatch while you put the struts on, or vise versa.
Old Nov 15, 2010 | 04:47 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
well the rear hatch weighs like 100 lbs....that being said, what the guys above me said, or if you absolutely have to install them at less than full extension, maybe some plastic zip ties? I seem to recall that shocks for other things sometimes come with zip ties on them to make them shorter for packing and or installing...
Old Nov 15, 2010 | 07:28 PM
Car: 91 Z28-L98/G92
Axle/Gears: 3:73
i proped my hatch up as far as it will go and the struts are still about 1inch short of fitting.the only way i can compress them is when i took one one off just to see if i could push it in and i had to put a small board on one end and leaned on it with my chest.even then i only got it to go in maybe 2in just for a second.i have them attached to the torx bolts and was trying to get them to fit in the the hatch slots.am i doing it the wrong way?.thank you for all the input
Old Nov 15, 2010 | 07:46 PM
Car: 91 Z28-L98/G92
Axle/Gears: 3:73
also im putting in new hood struts.anything i should know b4 i start
Old Nov 15, 2010 | 08:27 PM
AmorgetRS's Avatar
Get a friend to hold it up higher. It goes plenty high for them to be fully extended.
Old Nov 15, 2010 | 08:52 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
They kind of push onto a part that sticks out a little bit, I put mine on by myself, it's pretty easy.
Old Nov 15, 2010 | 09:04 PM
Car: 91 Z28-L98/G92
Axle/Gears: 3:73
ok il give it a shot.thanks everybody
Old Nov 20, 2010 | 03:25 PM
Car: 91 Z28-L98/G92
Axle/Gears: 3:73
i had my gf hold up the hatch and i got them on.i was just a little nervous about lifting the hatch to far.i for sure didnt want to crack the glass or anything.thank u to everyone for your help
Old Nov 21, 2010 | 12:03 AM
Engine: 3.8, 3.4
I don't think you could crack the glass from lifting it too far...worst that would hapen is you would tweak the hinges, but you would feel know if you went too far.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
Omega
Aug 10, 2015 10:24 PM
mustangman65_79
Aug 8, 2015 12:07 PM
