Rust repair... any advice?
Old Dec 10, 2010 | 11:40 AM
Andrew91GT's Avatar
Car: 1990 formula
Engine: 433 sbf + turbos
Transmission: powerglide
Axle/Gears: fab9, 3.50
The gold mine:
Any advice?
Old Dec 10, 2010 | 11:54 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Rust repair... any advice?
Craigslist.
There are too many rust free bodies out there, especially in the South, to waste too much time and $ on a body with rot. AND it's much more fun moving all of the cool stuff from one body to the other, then you wind up with all those EXTRA parts.
Old Dec 10, 2010 | 12:14 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Originally Posted by naf
Craigslist.
I'm with this gentleman and his extra clean 87 sport coupe.
I looked at a handfull of clean, almost perfect (rust wise) 3rd gens when I lived in NC this summer, just never pulled the trigger because I knew I was moving and didn't have the time.
Old Dec 10, 2010 | 12:48 PM
Andrew91GT's Avatar
Car: 1990 formula
Craigslist.
Is it easy to move a wolfe mini tub kit and coilover spring adjuster setup to a new body?
Old Dec 10, 2010 | 02:36 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
How much is in the rest of the car? That's just one spot. Looks bad but I'm also from the carolinas. They don't seem to rust as bad here. Tub kit won't help keep it from twisting.
Just saw that bracing. That'll help.
Old Dec 10, 2010 | 02:56 PM
Andrew91GT's Avatar
Car: 1990 formula
The front of the rocker area on both sides is rusty a bit. The rear of the passenger wheel well where it meets the firewall is rusty as well.
I have subframe connectors on the car and will put in a 10 point cage, but figured that I needed a sturday floorpan to weld the cage to first!
Old Dec 10, 2010 | 03:07 PM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I welded my bars to plates welded on top on rear LCA brackets, torque box area. The floor in that area doesn't sit on top of the brackets so I cut it out. The front floor does sit on the torque box.
I'm not an engineer but you probably want as much support as possible so I'd check out the rest of the car twice. Maybe speak with someone at a chassis/fab shop. Guess it's kind of, it's your car, whatever makes you feel safe. Is it race or street?
Old Dec 12, 2010 | 07:31 PM
norton750's Avatar
Car: 83 firebird
Transmission: 700
I supported my car with jacks front back and center, cut out all the rust and built new parts and welded it back togeather. SFC going in now. Be shure to look behind the front fender right forward of the door. some important structuer that is probly rusted too. Rust free cars are hard to find around here
Fireslash
Apr 11, 2016 06:43 PM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
