Wheel Well Tubs
Old Dec 31, 2010 | 05:13 PM
valicswarrior's Avatar
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
Wheel Well Tubs
Anyone got a link to a set of cheap wheel well tubs this car is only a driver which is why i say cheap not to mention doing the work on a budget or if you have a better idea for fixing my rear wheel well
Old Dec 31, 2010 | 05:45 PM
Stephen's Avatar
Car: 87 GTA
Re: Wheel Well Tubs
How bad/big is the area you need to fix? Several of us have just cut out what we needed to & welded in flat plates hammered to fit.
Old Dec 31, 2010 | 06:18 PM
Re: Wheel Well Tubs
big hole and theres a lot of soft area i really feel i need to replace it all
Old Dec 31, 2010 | 07:42 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Wheel Well Tubs
Do the paper cardboard trick, cut bigger then the area, with many slits where it willl curve, shove it in there till it fits the shape nice, mark any over lap and cut it out. Check n recheck before ya cut it out of some hardware sheet metal.
Beat in place, weld, rivit, glue, cover everything in fiberglass when done then rubberized underspray coating.
I can tell you, if you got that there, you got more you can't see, gut the inside of the car 100% [front and back carpet.] before you do to much. Then go from there.
Old Jan 1, 2011 | 12:03 AM
Re: Wheel Well Tubs
well i dont wanna go crazy i wanna pull back the carpet and the trim there and fix it but i dont wanna take the whole car apart i am in the middle of preping the body for paint and trying to do the window motor on passenger side dont wanna get too much going
Old Jan 1, 2011 | 12:43 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Wheel Well Tubs
Id worry more about the chassis then the paint, the paint isn't gonna hold it together in the middle.
Old Jan 1, 2011 | 12:48 AM
Re: Wheel Well Tubs
the frame good its just the wheel well is ****ed from the salt and **** getting kicked off the tire
Old Jan 1, 2011 | 02:56 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Wheel Well Tubs
All I can say is trust me, what may look nice from the bottom isn't always the same on top.
Been through it. Only could see rust like you got, till I looked closer.
Have yet to find anyone who had the same and didn't find more.
I need to edit my post from 04 as they must of turn off html but you can see
what I mean.
https://www.thirdgen.org/forums/v6/1...-p-my-car.html
Old Jan 2, 2011 | 02:28 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: Wheel Well Tubs
http://www.wolferacecraft.com/detail.aspx?ID=824
https://www.thirdgen.org/forums/susp...0-formula.html
Old Jan 2, 2011 | 03:48 PM
Re: Wheel Well Tubs
Well my passenger tub is Mint no rot what so ever gotta pull the interrior from the drivers side tomorrow and see how bad it is over there
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
