question about best body filler, and outdoor spraying
Old Jan 3, 2011 | 09:32 PM
yellowsnow's Avatar
what is that easy sanding body filler that you see the pros on TV use? i have used bondo and the fiberglass kind and both are so hard to sand that I can't make a smooth transition...
If I have a spot that the wind is blocked on all sides, is their any way i can spray outside and get a good paint job?? Or is that just a bad idea??
Old Jan 3, 2011 | 10:23 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: question about best body filler, and outdoor spraying
I use Evercoat Rage and I sand the first coat of filler with 40 grit and sand the second coat with 80 grit then apply a thin coat of putty and finish that with 180 grit and you should be ok spraying primer outside but I wouldnt pait outside
Old Jan 3, 2011 | 11:37 PM
gen3guy's Avatar
i have been working at a shop for a while and we use rage xtreme and i dont like it i like the rage or the rage gold is really nice if you are not doing heavy filling i would suggest trying evercoat easysand it fills a little more than their other metal glaze but is not for heavy filling just for small dents or dings or as a finish coat. I would not attempt to paint outside, prime sure but not paint.
Old Jan 4, 2011 | 12:25 AM
puma1552's Avatar
Just rent a paint booth from a shop.
Old Jan 4, 2011 | 02:29 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Painted my Firebrid outside and just recentaly my Buick wagon.
pick a nice calm day and paint the car in stages, hood n doors one day, back end n roof the next, just make sure and mask off the good area well and 100%.
Over spray sucks and will finds its way under any lose flaps of paper.
Though black hides allot; yet reveals bad body work.
1992 Trans Am
May 10, 2023 07:19 PM
project89
Sep 24, 2015 06:38 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
