Best hood choice for a carb setup?
Car: 1986 Iroc-Z
Engine: 355
Im looking for a new hood for my car, i recently swaped out my 305 for a carbed 350 and im using one of those heart shaped air filters because of the clearance issues.
Im thinking about going with either a 2' cowl or daytona hood.
Could the daytona hood be made functional? and does it give me anymore clearance than the stock hood?
Im leaning more towards the daytona hood but i like the that the cowl hood actually gives me some performance.
What happens with the cowl hood when it rains? does rain get in through the back of it? or does it close off?
Thanks for the info.
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Best hood choice for a carb setup?
Rain shouldn't get into the cowl unless you driving backwards at 60 mph. Some cowls are completely open in the back and some have perforated steel covering the opening. Either way it shouldnt be a probelm.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
JamesC
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
i would go with a cowl...i had a lift off cowl on one of mine....the only thing you have to worry about is snow getting in there, but if you cover it in the winter its no big deal, rain won't get in there
Car: 1986 Iroc-Z
Engine: 355
@84z28 lol yeah im mostly worried about the big puddles around here.. Here in houston it gets flooded all the time and i dont want some random guy to splash me water through the cowl.
@james My set up is probably at around the same height as yours im running an edelbrock performer. Which air cleaner is that? It seems like it will fit pretty snug. I just didnt want to end up buying one at my local parts store and end up returning it.
@86T/A yeah snow isnt a problem where i live
Thanks for the info guys, does anyone know anything about the daytona hood?
14 x 3" air filter with (IIRC) a 1/2" dropped base. The cost differential between a dropped base and a hood would be considerable (if the drop base will work, of course). I was content to find th above solution because I like the 'sleeper' look and cowl hood just wasn't going to do the trick for me.
JamesC
JamesC
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I currently have an Edelbrock performer intake, Holley Carb, and an edelbrock 14x3" drop base air cleaner and it fits fine under my Trans Am's factory hood, which has less hood clearance than your camaro. You should be fine with one of those. I actually removed one of those triangles of death from my motor to use this cleaner, I don't trust the foam they have..
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
the vette L88 should be the lowest air cleaner on the market for a 14x3 but no reason at all with that performer intake you can't fit an air filter under a stock hood
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i vote the cowl over the daytone hood. that thing is fugly.
as for rain, rain will get into a cowl hood, since the airflow over the cowl will go into the opening, the rain water off the hood will follow. It does it on my car when i get stuck in the rain. Never had it cause a problem though, but im sure if you hit a big puddle, you could have an issue.
but as people have said, with the right cleaner, you can probably fit this all under a stock hood.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
If interested, I'm running a Spectre 9in chrome air cleaner (didn't like the 14in touching the distributor), and I'm running a 2" filter in it. I get plenty of flow, since it's a straight 2in all the way around (as opposed to the drop-base), and this filter comes with a oil-charged reuseable cleanable filter. It's been great, and fits under my stock hood with Edelbrock Performer RPM intake and Edelbrock 1406 carb. No clearance issues even with the hood liner still in, and no issues with linkage or choke or dist wires (since it's only 9" and not drop base). Usually on the shelf at Autozone for $30 - here's the link on Summit: http://www.summitracing.com/parts/SPE-47708/
Car: 97 Cummins 92 CamaroZ28, 94 GSXR750
Engine: Modded 5.9 , carbed sbc358, modded
Transmission: Nv4500, 700R4 (for now)
Axle/Gears: stock
Ive got an SS hood with my setup and it fits just fine. Dont really know how much water will get in but im not to concerned.
Car: 1985 z28 camaro
Engine: 305 lg4,edelbrock,3"air cleaner.k&n
Transmission: turbo 700r4 w/b&m megashifter
Axle/Gears: Stock.
I have a ss hood also,and running a 1" carb spacer puts the air cleaner directly level with the scoop opening.I have a block plate that I carry in case I get caught in the rain.The air flow is still ok with the scoop blocked off.I rarely drive it in the rain,as it's not my dd.
Car: 83Z28 HO
Transmission: G Force 5 speed
Axle/Gears: stock
-Coltin
Street Lethal
Apr 30, 2019 12:14 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
