Fiberglass Blister,fixable?
Old Jan 21, 2011 | 04:11 PM
schmitt55's Avatar
Car: 1988 Trans Am GTA Notchback
Engine: 5.7
I Just bought an Original Notchback and it has the Blisters Issue. I was wondering if there is a permanent fix for it. I Know they said to sand and repaint but is there anything to FIX it right?
The car was red but was painted white at some point so my other questions are,
Do i have to sand till i see red?
What grit do i need to start with? Any difference of grit to sand the bumpers and the hatch? Also if you can please tell me what grit to start with and end with?
Car has no rust at all, its been a texas car all its life so i dont want to take it to bare metal. Thanks in advance!!!
Old Jan 21, 2011 | 06:15 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: Fiberglass Blister,fixable?
Blister in the paint? Could be the part was not properly prepped and the release agent caused the blister. If that is the case it would need to be taken all the way down to the fiberglass of SMC (which ever its made of). Either way the blister has to be taken down to where its begining from.
Old Jan 21, 2011 | 07:06 PM
schmitt55's Avatar
Engine: 5.7
yeah, its the original Notchback and i read an article that the paint bubble and that GM just said to sand it and repaint. I was wondering if there was something else that can be apply so it wont come back.
Old Jan 21, 2011 | 07:11 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
If that is the case then it sounds as if its a blister due to a release agent residue.
Sand and prep it properly. If you're doing this yourself, when you go to the paint store ask them for a cleaner used for plastics/SMC/fiberglass. The reason for that is the harsher wax and grease removers can soak into the material and also cause these problems later on.
Old Jan 21, 2011 | 07:30 PM
schmitt55's Avatar
Engine: 5.7
Thanks!! I really appreciate it!!! What Grit do i use in fiberglass? Like i stated the car was red and they painted white, Should i sand till i see red? Also the Notchback has some spider webs in the paint how do i tackled that? Same as the bumper?
Old Jan 21, 2011 | 09:31 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
I would sand it with 180 on a DA then when you have the imperfection feather edege then move on to 320 grit on a DA and prime with a good 2K primer if it has been resprayed white then there is a good chance that your problem may be with white good luck
Old Jan 22, 2011 | 12:24 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Be damn careful sanding it. You go through to the hatch material you can easily dig into it making a kind of dent in it. Worse than an A$$hole in the paint.
Old Jan 22, 2011 | 09:20 AM
schmitt55's Avatar
Engine: 5.7
Thanks for the advice, will it better (safer) to sand it by hand? I really dont want to screw something up.
Old Jan 22, 2011 | 09:42 AM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
If you sand by hand, I'd use a block or something to prevent you digging with your fingers. Personally I'd sand it with 80 on a DA carefully to get almost to the bottom of what is lifting. Then go to 180 and prime. Block with 180 till it's straight and smooth then another lighter coat or two of primer.
Old Jan 22, 2011 | 04:15 PM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Just depends on your skill level. If you're going to use a DA don't have it opened up wide running with a high pitch scream like a lot of guys do. You could even start off with a DA to knock out a lot of it and finish with a block.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
