so much undercoating............help
Old Jan 27, 2011 | 02:56 PM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
well it seems that someone went overboard with the undercoating and its every where. Its extremely tough Ive tried wire wheel, kerosene, torch and scraper (best so far)....
Is there anythign else I can try I hear everyone say kerosene works great but ive sprayed it down a few times and let it soak for hours and nothing its just as tough as before, Ive tried melting with a torch which works but then i hear people do that and then wipe whats left with kerosene. Thats not working it isnt taking any of it off.
Is there anything else I can try it took me 8 hours to do one wheel well and that not the whole thing. ALso tried a needle scaler which worked really well on parts that where super dried up.
Is there anyway to dry it out? or something else I can try stronger then kerosene.
i know this is a pain in the a$$ job but it seems like everyone else its alittle better then this.
Old Jan 27, 2011 | 03:20 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
Re: so much undercoating............help
Is it regular undercoating, or did someone put bedliner on it?
Old Jan 27, 2011 | 03:23 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I've got a stripe eraser that accepts a wire wheel that is pretty good for that. But like james said, if it's bedliner, the only thing I've found to do with that stuff is chisel it off.
Old Jan 27, 2011 | 03:27 PM
resop27's Avatar
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
honestly I'm not sure its not how do I put this "lumpy" like most bedliners I've seen.
Old Jan 27, 2011 | 04:37 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
It could be a cheap spray one, they are less textured to be able to come out of a rattle can nozzle.
Old Jan 27, 2011 | 07:16 PM
resop27's Avatar
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
Well then im not sure is there some way to remove it differently then undercoating.
Old Jan 27, 2011 | 07:43 PM
james94's Avatar
Car: 1990 IROC
Engine: Tree Fiddy
if its holding up so well, why remove it?
Old Jan 27, 2011 | 08:05 PM
resop27's Avatar
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
There's rust under some of it so id like yo remove it all and replace it
resop27's Avatar
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
And not just surface rust like metal has to be removed and replaced
Old Jan 27, 2011 | 08:34 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
try some aircraft stripper from auto zone, spray on can or jug, be careful. powerful stuff, will strip paint off a car in 3 sec, really just 3 sec.
Old Jan 27, 2011 | 10:16 PM
toomany's Avatar
^^^ He's not kidding. That stuff will eat anything it touches.
Usually I use a propane torch and something to scrape the undercoating off. Oxy/actyl works too. Either way it's no fun job. Becarfull of whats behind the area your heating...don't want to set the car on fire.
Old Jan 27, 2011 | 10:32 PM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
If your trying to get the stuff in the wheel wells out, it's not the same as the coating under the car. It's hard, thick stuff. I used a chisel and small hammer and just went to town and slowly chipped piece by piece away till it was gone. Sometimes you get lucky and a huge piece chips off but you won't get rid of it with just kerosene. Patience is key with wheel wells!
Old Jan 31, 2011 | 12:49 PM
ChromePhoenix's Avatar
Car: 85 Trans am
Engine: 350 carbed
Axle/Gears: 9 bolt rear disk
now this is only a rumor but i have heard of people able to use dry ice and freeze the stuff then use a ball peen hammer to kinda break it away once its brittle,
Old Jan 31, 2011 | 04:42 PM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I've heard the same thing but with the Q-pads on floors. Someone on the net claimed to loose 30 pounds or so in his car.
