4th gen outer door sweep complete seal?
Old Mar 9, 2011 | 09:00 PM
camaro1122's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 LB9 TPI
Axle/Gears: 2.73 posi drum
I just replaced the outer door sweeps on my drivers door. It took some time but looks great and seals pretty good. Now since i only did it on one door testing the fitment, etc does anyone know how to completely seal the window sweep so no water comes in? With the 4th gen door sweeps they cut around the morrow so on a certain part of the sweep its reduced. Everything else covers and even though you cant even see the part that was reduced, behind the mirror is pretty big gap that will let water poor in. What can i use to completely seal it and seal the rest of the sweep since maybe one area is not snug against the window?
Old Mar 9, 2011 | 09:15 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: 4th gen outer door sweep complete seal?
this is why i just bought new thirdgen sweeps...
Old Mar 10, 2011 | 07:13 AM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The 4th gen sweeps were obviously designed for the 4th gen, not the 3rd gen. Since mods had to be done to get it on the car, you'll have to find some mod to make it work right. Or, you could get the sweeps for a 3rd gen and call it a day! I wonder if the 4th gen trunk will fit a 3rd gen.
Old Mar 10, 2011 | 09:10 AM
Engine: L31 350
my point here, new thirdgen sweeps are cheap and easy to find, no mods needed, all you have to do is take out the what 5 or 6 screws to take the old on out then replace the old with a new and put the screws back in, easy as pie as some say. for $61 i got 2 brand spankin new sweeps that looks flawless
Terrell351
Jun 13, 2021 01:13 PM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
BlackTopKing
Aug 19, 2015 12:13 PM
89lsc
Aug 14, 2015 04:58 PM
