Front clip replacement. What am I in for?
Old Mar 14, 2011 | 11:48 AM
Mayjor's Avatar
Car: 1989 Camaro RS
Whats goin on u guys? Im about to get ready to start the body work on my car and i wanna try to do it myself. The whole front clip of my car has to be replaced...fenders, bumper, hood and everything. How hard is it? Is it something a novice could do?
Old Mar 14, 2011 | 02:07 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Front clip replacement. What am I in for?
fenders, bumper, hood isnt bad at all
But when you say everything are you talking about everything from the firewall forward? K member, frame rails, strut mounts, radiator support, etc? Those are no easy task.
Old Mar 14, 2011 | 02:52 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It's all just nuts and bolts. Some easier than others to get to (like everything else in the world), but in the end it's all just nuts and bolts.
Got to be easier than building the pyramids, and they had no garage or tools! Determination is free, yet it's the hardset 'tool' to obtain.
Old Mar 14, 2011 | 03:52 PM
Mayjor's Avatar
Car: 1989 Camaro RS
Na jus the body panels...everything else is gonna stay. Ive been readin around an everyone talks about how much of a pain replacing the fenders an such were so i was just curious if i should still try it myself or if id just be better of taking it to a shop. Thanks u guys as longs as its just "nuts and bolts" as described i should be able to handle it. Another wuick question though...my hood flipped up while driving on the interstate so the lifts that the hood are on are junked too...how hard is that to replace? Is it just bolt on also? Is there any other damage that i should check for?
Old Mar 14, 2011 | 04:23 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Be sure to buy allot of zip-lock bags.Your going to be putting the bolts/nuts and any small parts from each piece in a bag and labeling the bag. Like one will say left front fender. Or bumper cover. Like that. If you don't you will be In big trouble when putting it all back together.By the way I had a hood fly open once on the free way ,could have killed some one.Just for piece of mind I installed pins on the Camaro.
Old Mar 14, 2011 | 04:34 PM
Mayjor's Avatar
Car: 1989 Camaro RS
ya...mine had pins but i let the gf put em back in that night...an ya...never again
Old Mar 14, 2011 | 04:36 PM
Mayjor's Avatar
Car: 1989 Camaro RS
and thanks for the tip with the back...ill def do that
Old Mar 14, 2011 | 06:49 PM
3rdgenmaro's Avatar
Car: 88 IROC
yeah, you can do it. Might want to take a few pics as you go along too.
Old Mar 15, 2011 | 08:24 AM
torque_is_good's Avatar
Dang, I may have found a new signature.
Old Mar 15, 2011 | 08:29 AM
I have mine off right now. I'm in the middle of sanding, and sanding, and sanding and glazing, and sanding in preparation for primer then paint.
The toughest nut to get is the top one on the clip as it's tucked inside the fender and you can't get to it from the headlight.
But, once it's loose it will finger off. Remove the front clip and then take your headlight housing off of the clip.
Old Mar 15, 2011 | 12:11 PM
Car: 1992 RS
Engine: Carbed 350
It was pretty good wasn't it? Every so often my brain actually spits out something worthwhile (but don't tell anyone, you'll ruin my rep!).
ktthecarguy
Jul 5, 2020 11:46 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
dag19
Aug 26, 2015 10:22 AM
Dan Hubbard
Aug 12, 2015 09:05 PM
