Window Louvers Question
Old Mar 16, 2011 | 05:36 PM
AKcamaroAK's Avatar
Car: 1986 Chevrolet Camaro Z28
Engine: 350 V8 4bbl
Transmission: Automatic 700r4
Axle/Gears: 2.73 Open Diff
I have an 86 z28 (third brake light on the rear window), and I came across these window louvers on craiglist for a pretty good deal. First thing though, is will they fit on my car? http://anchorage.craigslist.org/pts/2263266918.html It says that it's from an '85, but it looks like there is an opening for the brake light in the picture..
Also, once I get them I wanna paint them black. I assume they're just plastic and all I need to do is lightly sand it then go over it with a few coats of Krylon plastic paint, is this correct?
Thanks a ton
-Daniel
Old Mar 16, 2011 | 05:41 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: Window Louvers Question
yes, those are for an 86, you're in luck
when I painted mine I used a primer meant for plastic,and then put a few coats of semi gloss enamel over the top of them. Just LET THEM DRY before you handle them,,, enamel takes longer to cure than you think it will
Old Mar 16, 2011 | 05:53 PM
AKcamaroAK's Avatar
Engine: 350 V8 4bbl
Alright awesome!
Your louvers look great, thanks for the tips.
Old Mar 16, 2011 | 05:55 PM
58mark's Avatar
you might luck out and find the aluminum ones...those don't look like plastic ones to me...
Old Mar 16, 2011 | 06:06 PM
AKcamaroAK's Avatar
Engine: 350 V8 4bbl
Really? That would be pretty sweet.
Another thing. If these don't come with the mounting hardware, where would be a best place to get the hardware? and how much would it be?
Old Mar 16, 2011 | 06:09 PM
58mark's Avatar
that's the trick... mounting hardware is impossible to find. If you buy them, they better come with everything, or you're going to be doing a lot of custom fab work.
for$150 it better come with everything, especially because the seller is basing his prices off what they go for new
Old Mar 16, 2011 | 06:12 PM
AKcamaroAK's Avatar
Engine: 350 V8 4bbl
Yeah I was just looking around trying to find the hardware with no luck haha..
I'll definitely make sure he has all the hardware. Thanks for your help
Old Mar 16, 2011 | 06:14 PM
58mark's Avatar
post up pics when you get them!
Old Mar 16, 2011 | 06:20 PM
AKcamaroAK's Avatar
Engine: 350 V8 4bbl
Will do!
Old Mar 17, 2011 | 02:23 PM
AKcamaroAK's Avatar
Engine: 350 V8 4bbl
Ok got the louvers. They look pretty good. Not aluminum though.. But it's all good. All the clips are in good shape except ONE, which I show in the picture below. I dont know if it really matters or if it's repairable? Maybe someone on hear can sell me an extra clip..
Broken clip:
All the clips look like this one except the aforementioned broken one:
There is a tiny bit of separation but I think it can be pushed back in, eh?
Overall I think I got a pretty good deal on these.
Old Mar 17, 2011 | 02:26 PM
58mark's Avatar
Personally, I wouldnt worry about one clip. ARe those clips the only things hold it on?
Old Mar 17, 2011 | 02:32 PM
AKcamaroAK's Avatar
Engine: 350 V8 4bbl
Yeah, the guy told me that you clip it on and tighten them down, or something to that extent.
Old Mar 17, 2011 | 02:34 PM
58mark's Avatar
Hmmmm. Put them on and see how ubstable they are before you go to a ton of trouble.
One clip out of several probably wont make a difference
Old Mar 17, 2011 | 02:39 PM
AKcamaroAK's Avatar
Engine: 350 V8 4bbl
I was thinking it wouldnt, but I didn't want them blowing off going down the highway haha. I'll put them on this weekend if it stops snowing here.
Vintageracer
Jan 10, 2020 05:33 PM
pfsteichen
Feb 9, 2016 06:59 PM
RedLeader289
Jan 22, 2016 03:05 PM
redmaroz
Aug 16, 2015 11:40 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
