So long, TGO - nevermind(car saved)
Old Mar 17, 2011 | 12:06 PM
Skyset's Avatar
Car: 86 Iroc-Z
Engine: 305 (TPI)
Axle/Gears: i dunno lolz
I'll miss trolling you guys. Unfortunately, my front right wheel literally broke off the studs on the way to college yesterday, and the car drove over the wheel, and up the fender, panel, molding, and paint on the door. I can't afford the $1900 the body shop wants to repair it, oh well.
the pic of the car is below
Old Mar 17, 2011 | 12:09 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: So long, TGO
Awww crap!!!
Old Mar 17, 2011 | 12:10 PM
herbz28's Avatar
Car: 1987 tpi camaro not sure of motor
Engine: 5.0 tpi
Transmission: 5spd
Axle/Gears: posi track rear end gears unknown
Re: So long, TGO
alot of that stuff is really easy to fix yourself. Fenders are pretty cheap if you know where to find then so look on the bright side at least your ok
Old Mar 17, 2011 | 12:12 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Re: So long, TGO
I bet there's somebody out there that could give you a hand in fixing it. That doesn't look that bad. all those parts come off easy, and are cheap to replace
58mark's Avatar
Re: So long, TGO
beat me!
Old Mar 17, 2011 | 12:29 PM
unknownghost's Avatar
Car: 1989 IROC-Z
Re: So long, TGO
That sucks.. but it could be worse. You could definitely get it back together for less than $1900. Hell, you could even do it a bit at a time if you needed to.
Old Mar 17, 2011 | 12:47 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: So long, TGO
Wow, thats impressive. I think your car was trying to tell you it was time to change some wheel studs. Your car needs to learn what subtle means next time
Old Mar 17, 2011 | 01:09 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: So long, TGO
Get some studs on it and drive it, browse craigslist when you put together a few bucks find some clean used parts and slowly put it back together.
Do you have insurance
, a deductible is cheaper than a body shop or take your time and do it all yourself.
Old Mar 17, 2011 | 02:18 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: So long, TGO
No retreat! No surrender!!
Old Mar 17, 2011 | 02:59 PM
87 player bird's Avatar
Car: 87 player's trans am a4u (pepsi car
Engine: 305 tpi
Transmission: 5 speed
Axle/Gears: 3:42
Re: So long, TGO
Not going to part it are you? IF so how much for the whole car? Hope you can fix it your self.
Old Mar 17, 2011 | 05:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: So long, TGO
looks like you could swap the fender and put a new rotor/hub on it and it would be perfectly drivable. Its all bolt on parts and if you have any mechanical ability is should be too hard to fix up, paint doesnt HAVE to be done right away.
Old Mar 17, 2011 | 05:06 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: So long, TGO
Old Mar 17, 2011 | 05:38 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: So long, TGO
I say, get it drivable and fix the rest when you can......
Old Mar 17, 2011 | 05:56 PM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
Re: So long, TGO
yes just replace studs and drive it like that ebay has fenders for 70 bucks i think you can get it back on the road and work on it when you can cheaper than buying a new car as well
Old Mar 17, 2011 | 06:06 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: So long, TGO
LOL. $1900 for that? Talk about a rip off. Be sensible about what you're doing here.. You have a ding in your fender that looks ugly and you're giving up on a whole car because of that? You can find fenders all day long for $50 around here, and another $50 for ground effect pieces.
You could fix that by yourself for under $400 and that's including high grade paint, clear, and primer. It's not like your quarter panels got trashed or something difficult... this is an easy fix in the scheme of things. You could be driving this again after a few hours of work.
Old Mar 17, 2011 | 06:21 PM
MI ROC-Z's Avatar
Car: 89 IROC-Z
Engine: L98 5.7 liter
Transmission: TH700r4
Axle/Gears: limited slip 3.23
Re: So long, TGO
Pull the rotor off, press in new studs, put on a used front fender, and pull out the front edge of the door... done!!!
That's what I would do and then drive that sum bisch!
Old Mar 17, 2011 | 06:30 PM
travis401's Avatar
Car: 91 Camaro RS
Re: So long, TGO
you cant call in quits because of that little damage. its not like youre front end is sitting behind your seats now....
Old Mar 17, 2011 | 06:35 PM
Dartht33bagger's Avatar
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
Re: So long, TGO
That's not even that bad. You better fix it and get it back on the road.
Old Mar 17, 2011 | 07:05 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: So long, TGO
FIX IT YOUR CARS IS GORGEOUS!!!!
Old Mar 17, 2011 | 08:08 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: 4L80e
Axle/Gears: C5 IRS
Re: So long, TGO
WOW, this site is all about how to fix things yourself! that damage is so minor that I would consider yourself very lucky that its all bolt on stuff that is readily available.
Old Mar 17, 2011 | 08:26 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Re: So long, TGO
You can rebuild it, we have the technology.... bigger, stronger, faster.
Old Mar 17, 2011 | 08:28 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
Re: So long, TGO
thats pathetic..who just upright ditches the 3rdgen world because of somethin so small and easy to fix..that tells me you werent realy into these cars like most of us are anyway.
oh well, HOW MUCH FOR IT???? and yes, im for real
Old Mar 17, 2011 | 08:58 PM
Engine: L31 350
Re: So long, TGO
lmao, gotta love us indiana boys
Old Mar 17, 2011 | 08:59 PM
travis401's Avatar
Car: 91 Camaro RS
Re: So long, TGO
If i wasnt all the way down here id buy that in a heartbeat...
Old Mar 17, 2011 | 09:51 PM
tekkitan's Avatar
Car: 87 IROC-Z
Re: So long, TGO
Eh if he wants to leave after such minor damage, he obviously didn't really want to keep the car. Good riddance I say.
Hell his car STILL looks better than mine and mine has four wheels :P
Old Mar 17, 2011 | 10:05 PM
Axle/Gears: 4.11
Re: So long, TGO
Sounds like might have been uninsured?! No reason to have to pay that out of pocket.
Old Mar 17, 2011 | 10:08 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
Re: So long, TGO
that could be fixed in half a days work..
Old Mar 17, 2011 | 10:17 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: So long, TGO
Hell, I did more bodywork than that on my car!
I got the pics in my vb garage to prove it.
I got the entire car painted, new doors, hood, fenders, bumper for about $1000. And it was only $1000 because I had to pay someone to spray the entire car. If I had a place to make a booth and had an air compressor I could have done it for $400 total.
Old Mar 17, 2011 | 10:20 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: So long, TGO
fix it yourself. or dont. either way you can still post here. but whatever. (peace)
Old Mar 17, 2011 | 10:30 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Re: So long, TGO
Someone else will buy it at his loss. He's delusional if he actually thinks he's going to come out ahead by quitting in any respect, though. If that's his attitude on the thing though - he'll just end up driving some grocery-getter anyway. Prius? Perhaps.
Old Mar 17, 2011 | 10:56 PM
travis401's Avatar
Car: 91 Camaro RS
Re: So long, TGO
Civic...
Old Mar 17, 2011 | 11:03 PM
puma1552's Avatar
Re: So long, TGO
Insurance?
Old Mar 17, 2011 | 11:25 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Re: So long, TGO
Originally Posted by puma1552
Insurance?
They'd most likely total the damn thing...so...lets not get insurance involved...the car after putting new studs which is what...$10-20???? Or less?? Then the car is driveable?? I agree with others...if he isn't aware enough to realize that...how much for the car?
Old Mar 17, 2011 | 11:53 PM
Axle/Gears: 4.11
Re: So long, TGO
I doubt they would total that for 1200..up to him what he does with his car though. Think hes crazy for selling it because of a fender. What happens when the next one has a cat that goes bad?
Old Mar 18, 2011 | 01:05 AM
travis401's Avatar
Car: 91 Camaro RS
Re: So long, TGO
depends on how much they value the car at...which with our cars is usually around $2500. and insurance usually totals cars when the estimated repair hits about 70%-80% of that assessed value.
Old Mar 18, 2011 | 01:31 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: So long, TGO
BTW. This is a remind to torque your lug nuts with a torque wrench. 100 ft lbs with stock wheels if you have the 12mm threads. You can do it to 90-95 and be safe still. Overtorqueing or improper torque sequence can cause brake vibrations/pulsating better know as warped rotors. can cause damage to wheel studs. etc.
Old Mar 18, 2011 | 02:14 AM
Slash's Avatar
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
Re: So long, TGO
Shame... more to teh fact your giving up after something minor
TBH in reality he probably got scared of the car when this happened and just doesn't want to continue with it, sort've understandable but no excuse. Gotta get back up on that horse, as some would say
Old Mar 18, 2011 | 08:04 AM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Re: So long, TGO
No regrets, no remorse!!
Old Mar 18, 2011 | 01:02 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: So long, TGO
No repair, no reward???
Old Mar 18, 2011 | 05:42 PM
Camaro-454's Avatar
Re: So long, TGO
Shoot, No Way would I give up on such a cool looking, styling, good riding car like that. Over that little bit????
$1900.00? I'd be laughing all the way out the door, saying keep your fix thank you very much. They are Definately trying to rip you off. And yes they will take your money if you're stupid enough to give it to them. ( and I'm Not calling you stupid, as if you don't know you just don't know any better ).
There's so many pluses to this right off the bat. First off, he owns he car outright, he's not making any payments on the car. He didn't say anything about having Any problems with how the car drives, transmission slipping, loosing oil, compression, engine block cracked, coolant leaks, Nothing, so I can only assume that all of that's good. It's an easy and inexpensive fix, and even if he cant do the work himself or would really rather not, simply by calling around he can find an Honest mechanic that could give him a fair price and he's back in the saddle again. There's plenty of TGO members on here in his area that would be more than willing to help him out if he just asked for it I'm sure. A little compensation to show his appreciation and he's easing on down the road once more like nothing ever happened.
Anyways, that's my two cents on the deal. Hopefully he'll reconsider, but that's up to him. He may already be gone as I have not seen him respond to any of the posts so far.
In any event, whatever he decides to do I wish him well, but if it were me, I'd fix my baby and ride on. I'd learn all I could about my car and do as much of the work as I could myself, and pay someone else tpo do what I couldn't, but that's just me.
Camaro-454
Old Mar 18, 2011 | 08:51 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: So long, TGO
Replace the broken studs & CHECK THE OTHER ROTOR TOO.
As has been said more than once already & is about to be said again.That is very minor damage.Some members here have repaired FAR WORSE cars than yours.Thats just a few hundred bucks to fix, tops.
When an onwer likes his car just enough to drive, but not near enough to repair becuase of minor damage.Another 3rd gens goes to the scrap heap.It sounds like your just looking for an excuse to get something else & its a shame too.This is how these cars end up in the crusher.
Mishaps are gonna happen.You cant just expect to keep driving the damn thing ***** nilly.Are you gonna get rid of every car you own when a little something goes wrong with it?
With todays society.It seems like the younger generations treat cars like diposable items.Just drive it, throw it away when it breaks & get a new one..Cars should last a lifetime (barring acts of god, etc).You cant just toss them by the waysside.Its not a laptop or cell phone for christ sake.Your GFX's arent even busted.**** like this pisses me off (no offense)...fix it....please.
Old Mar 19, 2011 | 01:00 AM
  #42
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Re: So long, TGO
I agree! I bought most of my thirdgens not running (And some of them still dont run!) Put a little work into it, you'll be glad you did! Pride of ownership comes from blood, sweat and tears (And a flat wallet!) Get dirty and fix it.
Old Mar 19, 2011 | 10:30 AM
  #43
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Re: So long, TGO
I had some hail damage on my '00 GTP that is not very noticeable. Insurance almost totaled it because I had the transmission out at the time to rebuild it. Apparently they take things that need repaired into account when assessing.
Old Mar 19, 2011 | 10:56 AM
  #44
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Re: So long, TGO
Come on man, fix it! It can be done your self for a decent price.
Old Mar 19, 2011 | 11:22 AM
  #45
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Re: So long, TGO
Up here they will total anything over 14 years old.... take it or leave it...
As far as my socialist government is concerned, my car is a 22 yr old POS (with 60K on it!!!!) & is worth nothing if I get into an accident.
Regardless of it's mint condition I'd lose it!!!!
There's no way that I'd go to insurance over that fender and door... fix it or sell it!!!! & Keep the Sh*tHeads (Gov. Ins.) outta the equation
Old Mar 19, 2011 | 05:26 PM
  #46
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Re: So long, TGO
That sux dude
I have everything here to fix that and I'd probably do it for free (minus paint match)
Just remember how good it handles compared too almost anything out there. You will not find another car (even a 4th gen) that accelerates, goes around corners and gets 25mpg.
Everyone else check you lugnuts and notice that one of his was not on at the time of the mishap.
Old Mar 19, 2011 | 10:10 PM
  #47
Re: So long, TGO
I didnt even notice that, until you said something!
Old Mar 19, 2011 | 10:51 PM
  #48
Gibson's Avatar
Car: 1989 Camaro IROC-Z
Engine: LB9
Axle/Gears: 3.08 G80
Re: So long, TGO
fix it or ill come and slap you around. i spun my car doin 110 in hte snow (dont ask, long story) and broke a freaking axle, busted up my gfx, broke a wheel, and dented my rear 1/4 pretty bad, and i fixed it and kept goin. grow a pair man!
Old Mar 20, 2011 | 12:15 AM
  #49
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: So long, TGO
how many miles on the bilsteins?
Old Mar 20, 2011 | 12:30 AM
  #50
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: So long, TGO
I got almost everything if not everything to fix your car. Im located in mississauga and noticed your from toronto
