Weld on cowl
Old Mar 31, 2011 | 09:50 AM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Weld on cowl
Hey everybody! I've been searching for a 3" weld on cowl for my Camaro with no luck. I've seen a few mods where people just cut flat hoods and made cowl hoods out of them, but I think that's a bit over my welding ability. Does anybody know a place that sells them? I can find fiberglass ones all day, but it seems harder to find metal ones. Thanks in advanced!
Old Mar 31, 2011 | 08:26 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Weld on cowl
never seen a weld on steel cowl, only 'glass
Old Mar 31, 2011 | 08:49 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Re: Weld on cowl
I wonder why that is...From what I've been reading is that glass scoops on a steel hood generally have cracking in the filler shortly after it's done. Is this true, or are those people just bad at body work? You'd think a weld on cowl would make sense, it would be a lot cheaper than a whole new hood...
Old Mar 31, 2011 | 08:56 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Weld on cowl
i would think welding a piece of steel that large would probably warp the hood, and require a lot more time and money to finish properly than a new steel cowl hood would cost or a 'glass one. Your still going to have to use filler on the hood after welding since you will never get the metal perfectly flat and formed after welding/grinding.
as for fiberglassing to a steel hood, it will crack eventually since the hood does flex when its opened and shut.
Old Mar 31, 2011 | 09:04 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Weld on cowl
Goodmark is the only maker of steel hoods, that I know of.
http://www.summitracing.com/search/brand/Goodmark/Product-Line/Goodmark-Steel-Cowl-Induction-Hoods/Make/CHEVROLET/Model/CAMARO/Year/1990/?Ns=Rank|Asc
If your just looking for an add-on scoop piece, I found a 2 1/4" one.
http://www.e-bodyparts.com/Car-Hoods...es/SCOOP03.htm
BUT in more searching, I found this place that sells 3" ones.
http://www.indemandautoparts.com/cowlhoods.htm
Old Mar 31, 2011 | 09:07 PM
SumDumbGuy's Avatar
Car: 1987 Camaro
Engine: 355
Re: Weld on cowl
Hmm...You make valid points. I guess I have to start looking for a whole hood then. I'd hate to put a fiberglass scoop on and then waste money painting the car if it's just going to crack and have to be fixed. Thanks for the info!
Old Mar 31, 2011 | 10:03 PM
burn0ut305's Avatar
Car: z28
Transmission: pro built 700r4 (road racing kit)
Re: Weld on cowl
Im assuming fiberglass cowl on a fiber glass hood would hold up a lot better? either way after seeing the price of some of tho's scopes, a ture cowl hood sounds like the best way to go...
thanks for posting this thread, i've been playing around with the idea of getting a hood off of cl for 50 bucks or so and trying this... guess ill just take that 50 bucks and put it to a new hood...
Old Jun 16, 2011 | 04:04 PM
erictheviking's Avatar
Car: '92 RS Camaro
Engine: 406ci D1SC SBC
Transmission: TH400
Axle/Gears: 9" W/Truetrac
Re: Weld on cowl
This is what Im after. Because I live in the UK, getting an all steel hood, is very very expensive, due to the shipping and all the added taxes.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
no green
Jan 9, 2016 09:22 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
loud91rs
Oct 5, 2015 10:05 PM
