Wrong fenders?
Old Apr 12, 2011 | 07:03 PM
Rickj350RS's Avatar
Car: '90 Camaro RS
Engine: Aluminum Brodix-block SB 427
Transmission: Turbo 400
Axle/Gears: Moser 33 Spline 4:10
Wrong fenders?
I have a 90 Camaro and I'm trying to replace the front fenders, but I've run into a bit of a problem. My 1990 front nose has tabs that accept a flat bracket with three studs coming out of it. However, the fenders that I'm trying to fit have two slits instead of three holes. Am I ok to use these fenders? Do I just have to drill the three holes and I'm good to go? Any help would be much appreciated. Thanks!
Old Apr 12, 2011 | 07:10 PM
chevydrvr's Avatar
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
Re: Wrong fenders?
The fenders are all the same shape on the outside and will look the same regardless. They probably just changed the mounting methods between years. I would say you could just do what you said and be all set.
Old Apr 15, 2011 | 07:58 PM
jer4251's Avatar
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
Re: Wrong fenders?
you need 1990 and older fenders, the ones you got are for 91-92 camaros with the different style ground effect. I have a pair of 90 and older and i plan on cutting the slits open to work on my 91
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jovibuilt
Oct 18, 2015 08:12 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
