How much seam sealer
Old May 5, 2011 | 03:00 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
How much seam sealer do I need to redo the inside of my firebird? I have the carpet out and I am going to reseal it after some POR15.
Also I know about the 3m stuff does anyone know about an alternative maybe a home depot item? I am thinking an outdoor adhesive would work.
Old May 5, 2011 | 07:00 PM
lonesomeloser's Avatar
Car: 1983 Z28
Re: How much seam sealer
I don't know how much you'll need. I haven't done mine yet. But, you can get seam sealer in a big tube at the autoparts store. I'd worry about a home improvement sealer shrinking and cracking.
Old May 5, 2011 | 07:39 PM
RCR3's Avatar
Car: '91 Z28, '04 2500HD
Engine: 5.7
Don't use a sealer that is meant for houses. 3M makes a brushable seam sealer that comes in a can, and you can spread it with a acid brush. One can should be plenty for what you are doing. Transtar is a company that may have a cheaper version. Don't get that POR on your skin, only time takes it off.
Old May 6, 2011 | 10:48 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Personally, I'd rather use clear silicone sealant that will still be flexible in 20 years or so and not be easily removed with just a poke (literally, that's how most of the sealer along my floor board joints came out!), but I already have the 3M 2-part seam sealer that requires a special applicator gun (THAT was expensive , but necessary for the body panel adhesive I got with it).
Heck, I've used the clear silicone to repair a headlight lens assembly on a Dodge that leaked water inside and fell apart twice before I fixed it...
midias, it's your choice... It may take a few tubes, however, of whatever you use if it's not the can stuff described above (which is recommended by GM, BTW). They sell gray generic auto body seam sealer at parts stores (I have a tube of that as well I was going to use for something else but never did).
Rousseau92maro
Feb 1, 2016 05:12 PM
jaridjohn
Oct 5, 2015 07:01 AM
corey8084
Sep 17, 2015 02:56 PM
Amillionoh7
Aug 7, 2015 01:24 PM
AlexJH
Aug 19, 2001 07:13 PM
