Coolant and Washer Tanks
Car: 85 Camaro Z28
Engine: 5.7 TPI
I am looking for new replacement tanks for my 89 Camaro. The coolant tank part number is 10170175 and the washer tank is 22063426. According to my local dealer, they are no longer available.
Is there somewhere else to get these? All the sites I have checked only show the 82-88 style. My style is the slightly larger ones and the washer tank has the hole for the tank mounted washer pump.
Any help will be greatly appreciated.
Or Iif anyone knows how to modify the older tanks to accept the in-tank mounted washer pump.... I can live with the other tank design if theres a way to modify it for my in-tank pump....
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Car: 85 Camaro Z28
Engine: 5.7 TPI
Re: Coolant and Washer Tanks
They are discontinued with hawks....only style available anywhere that I have found is the older smaller version.... I could live with the smaller tanks if there was a way to modify it to accept the in-tank pump....
Car: 85 Camaro Z28
Engine: 5.7 TPI
Ok my local dealer finally stopped being lazy. They located the proper coolant bottle in Houston and has ordered it for me. However, they cannot locate the washer bottle on a nationwide search. Does anyone know how to modify the 82-88 washer bottle to accept the 89-92 in tank washer pump?
i have a 1992 rs and bought my windshield washer bottle from gmpartsdirect. will the 89-92 washer bottle fit? if so buy the pump also.
Car: 85 Camaro Z28
Engine: 5.7 TPI
i am trying to find the 89-92 style as thats what fits my 89 camaro..... they are discontinued....... However, the 82-88 style is still available.....go figure....
If I purchase the 82-88 style, is there a way to modify it to accept the washer pump from the 89-92 version. 82-88 style did not have a tank mounted pump.....
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
GM parts direct still sells them new. Cheap as all get out too. Like 15 bucks each. Dresses up the motor nicely.
Engine: gone
Transmission: gone
Axle/Gears: gone
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
[QUOTE=coryprine;4923122]Ok my local dealer finally stopped being lazy. They located the proper coolant bottle in Houston and has ordered it for me. However, they cannot locate the washer bottle on a nationwide search. Does anyone know how to modify the 82-88 washer bottle to accept the 89-92 in tank washer pump?[/QUOTE]
Just use the 88-up bottle/pump.Better off that way.
Car: 85 Camaro Z28
Engine: 5.7 TPI
Guys, I have said it several times....discontinued.... the part number does not even pull up on gmpartsdirect any longer....
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
maybe paint the old ones with plastic paint??......theres a thread here somewhere for that. I think I'm going to paint mine....they're just gonna turn thatcrappy color again down the road
Car: 1986 IROC T-TOP
Transmission: 700-R4
