third brake light location
Old May 25, 2011 | 03:29 PM
murd450's Avatar
Car: 83 Z28
Axle/Gears: 4:11:1
Ok I've been a member of this board for quite some time , have read the camaro white book , have had 8 third gens , reserched the diferance between the year groups to find the best qualitys and to find the best parts, like 82-83 being the only years with factory glass hoods, and 86 being the only year with the third brake light at the top of the back window, I got some guy insisting he has an all original 89rs with the third brake light at the top of the back window-- what do you guys think!
Old May 25, 2011 | 08:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: third brake light location
89 RS should have had it in the rear spoiler. He probably just hasn't accounted for the fact that, he hasn't owned the car since the showroom, and therefore anyone could have changed rear decks at anytime.
Old May 25, 2011 | 08:32 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
not sure of the years . some early ones had none . then they had them on top of the hatch . then they were in the spoiler (89's) , and last were inside top of the glass . i would bet a 6 pk. that his does not work . more likely than not his rear glass has been replaced at some point in time . cheers !!!
Old May 29, 2011 | 09:13 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
My 92 RS has it inside the top of the glass hatch window.
Old May 29, 2011 | 09:17 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
86 is the only year it was on the OUTSIDE of the rear glass. The later years where it was "on" the glass. It was INSIDE under the glass.
But yeah...His 89 has had the hatch replaced at some point. I forget exactly where the 3rd brake was then. In the spoiler?
Old May 30, 2011 | 12:15 AM
80srobot's Avatar
i bought an 86 in part because i like the look of the light on the hatch rather than in the spoiler, its def the 86
Old May 30, 2011 | 12:17 AM
91 1LE's Avatar
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
'86 was on the outside top of the hatch glass. '87-'90 Z28's was 5 separate bulbs in the spoiler on the hatch. '91-'92 Z28's with the Aero spoiler and RS's were inside the top of the rear glass.
Old May 30, 2011 | 12:41 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
I have had the 86 Iroc , the brake light was on the out side of glass.
I have a 89 now, brake light on the spoiler.
I have a 91 RS brake light on inside of glass.
The rear hatch glass had to be replaced! for sure!
Old May 30, 2011 | 09:15 AM
On which car do you need the hatch replaced?
Old May 31, 2011 | 02:58 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The only other year the 3rd brake light was on the outside glass was 1987. It was only on the glass if you purchased a car without the rear spoiler. By 1988, there were only 2 options, Sport Coupe and Z28, which both had rear spoilers. All 1989 RSs has the light in the rear spoiler. If the car in question does not have a spoiler light and only a glass light, then the rear hatch has been replaced. If it has both, then the rear glass was replaced. As was mentioned, I will also bet that the brake light doesn't work in the glass.
Old May 31, 2011 | 03:17 PM
I thought 86 was the only year to offer the outside third brake light. The TGO tech info should include this, but it doesn't.
Old May 31, 2011 | 04:33 PM
MYLILREDZ28's Avatar
Car: 1992 Camaro Z28 with T-tops.
Engine: 305 5.0L, TPI, HO
Transmission: Borg Warner 5 speed, 77mm, 2.95
Axle/Gears: posi rear end, 3.08 ratio
The '86 model year was the first year for the "Third" brake light for all cars made. The '86 camaro was located on the top outside of the hatchback glass. I'm sure that the '87 thru '90 had it in the spoiler. The '91 and '92 camaro's had it in the inside top of the hatchback glass.
Old May 31, 2011 | 06:45 PM
scottmoyer's Avatar
And as I've already stated, 1987 also had it on the rear glass if the car didn't have a rear spoiler.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
