Air intake setups/systems
Old Jun 13, 2011 | 01:24 PM
RMR94's Avatar
Car: 92 camaro
Engine: 305 bonestock sbc
Transmission: 700/r4
Hello I was wondering if anyone would like to post some pics/ show ideas of there air intake set ups. And what there thirdgen temperature runs at. But I'm really interested in seeing how people have there air systems set up. MOre interested I'm tbi setups
Old Jun 14, 2011 | 06:53 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Re: Air intake setups/systems
Still working on that.
The most important part in the setup:
A working airdam.
Ever since I mounted it under hood temperatures allow comfortably running an open element filter, which is what I'm aiming for when using TBI.
The rest will either be an over complicated ram air type of setup utilizing the front fascia openings on the camaro and a TPI plastic intake piece or alternatively a cowl induction hood.
haven't decided on that part yet.
Old Jun 15, 2011 | 09:44 PM
RMR94's Avatar
Car: 92 camaro
Looks nice did you modify that? And what temp does your car run at?
Old Jun 23, 2011 | 04:23 AM
Engine: LO3
Sorry for the late reply.
The clearance to the ground is 4" which is the minimum I need at that location. Otherwise I'd lose it when leaving the garage.
A stock airdam sat slightly lower (2") before I swapped out the springs and shocks front and rear, back to original.
Car runs at 160-170 degrees F at cruisng speeds (40 mph and over) without fan, and even on 95+ degree F days (made a few testruns on the few warm days we had here)
Warms up to 185 degrees F on longer runs, but does not even exceed that at Autobahn speeds (100 mph and stuff)
Only time I get the car to 220 is in extended stop & go traffic, like 30 minutes or longer of crawling through traffic at speeds slower then 30 mph. As soon as speed rises, temperature drops again.
I measured through WinALDL because I did not trust my gauge untill I saw it isn't actually that far of (about 20 degrees too high)
1992 Trans Am
May 10, 2023 07:19 PM
stalkier
Dec 6, 2015 11:25 PM
kyle5647
Aug 15, 2015 11:56 PM
Jake_92RS
Aug 11, 2015 10:39 AM
