Wanted to see: Cowl Induction hoods
Old Jun 19, 2011 | 07:47 PM
skinny z's Avatar
I'm looking to build a cold air induction set up for my Coupe and as much as I don't want to add a cowl hood, it looks like that's the only (practical) way to do it.
I'd like to see who has what for hoods and how you've sealed things up to the carb/air filter.
The cowl hood I prefer the most would be along the lines of a 1st gen Camaro with a small rise (1 5/8" according to GM). I like the overlap into the windshield too.
Post your pics.
I also like the Sunoco hood.
Old Jun 19, 2011 | 07:50 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Wanted to see: Cowl Induction hoods
my air pan
i love the sunoco hoods. wish they made one for the birds...
Old Jun 19, 2011 | 07:51 PM
skinny z's Avatar
That looks efficient. How much of a cowl rise is it?
Old Jun 19, 2011 | 08:31 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I havnt built an air box yet. I just bought the tallest filter assembly I could to stick up the farthest I could to suck in the most cool air I could. But I do plan on making a box and this thread will help me decide a good option too!
I know I saw someone post up they used a circular pan almost like a stainless baking pan. Cut it. Use a rubber sealing and wham done. I think I saw it in the TBI section...
Old Jun 19, 2011 | 10:20 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Old Jun 19, 2011 | 11:59 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
here is mine
Attached Thumbnails Wanted to see: Cowl Induction hoods-gta-cowl-023.jpg   Wanted to see: Cowl Induction hoods-gta-cowl-024.jpg
Old Jun 20, 2011 | 01:32 PM
skinny z's Avatar
Originally Posted by //<86TA>\\
my air pan
[QUOTE=midias;4956453]
Originally Posted by formula forever
here is mine
To those that have replied, how much of cowl was the hood advertised at? One man's 2" is another man's 3" (so to speak).
Old Jun 20, 2011 | 02:29 PM
midias's Avatar
Yea a lot of the time some men measure an extra inch. I will get a ruler on it tonight and let you know.
Old Jun 20, 2011 | 08:43 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
3inch harwood show
http://www.cecoatings.com/images/Car...rfolk%20Beach/
Old Jun 20, 2011 | 08:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
[quote=skinny z;4956900]
sorry, mine is a 4.5" cowl, doesnt help much since its a bird, but the rear is 4.5" and it slowly tapers down from there towards the front.
Old Jun 20, 2011 | 11:38 PM
Car: 91 formula
mine is a fiberglass harwood 4 inch hood. i must say it does block alot of your view. in my opinion anything over a 4 inch is very difficult to see over. but im use to the hood now.
Old Jun 20, 2011 | 11:54 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
mine is a goodmark 2 inch cowl but it measures almost 4 at the highest point.
Old Jun 21, 2011 | 12:22 AM
EvilCartman's Avatar
Car: '82 Z28
3 inch Harwood
Then here's the pan I did for it. Used Moroso's replacement foam and a flat sheet of aluminum.
Old Jun 21, 2011 | 07:55 AM
skinny z's Avatar
Those are ALL fine looking cars (even the Firebirds!).
I found this hood at a distributor (just out of Chicago) for AMD sheet metal . Advertised as a 2" cowl. Good deal too with $100 off the on-line price at AMD. About $350 taxes in and I can pick it up and save the shipping.
Old Jun 21, 2011 | 09:47 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
I wish someone offered a steel cowl that extends towards the windshield like some of the fiberglass ones, like the Harwood one do.
For ease of mounting and every day use I'd prefer a steel hood over a glass one, even if the glass one is only about 1/3rd of the weight.
As for optimizing airflow from a cowl hood, would this be thinking too complicated?
I think it should be fairly easy to reproduce and slightly improve on the design for a few $ on fiberglass and a bit of work. Only real benefit over as simple a setup as EvilCartmans, which definately looks like the quickest good working solution, would be that you can fit this using the original aircleaner holding equipment.
Old Jun 21, 2011 | 10:29 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
I found this hood at a distributor (just out of Chicago) for ADM sheet metal . Advertised as a 2" cowl. Good deal too with $100 off the on-line price at ADM. About $350 taxes in and I can pick it up and save the shipping.
that looks like mine which is goodmark. did ADM buy out goodmark?
Old Jun 21, 2011 | 10:38 AM
skinny z's Avatar
I believe the unit pictured would require the firewall (below the cowl) to be cut as it has a dropped base and the filter lid would be at approximately the same height as a traditional open element. This puts the top of the enclosure just about even with the top of the cowl (which is part of the clearence problem to begin with).
I had thought about opening up the firewall, (in an attempt to keep my flat hood) however the distributor is directly below (limiting the available space) and the windshield wiper motor is just off to the side posing another restriction.
Now if you were to be creative and build something similar ( as you suggest) then you may provide solutions to the space limitation problem.
The cowl hood solves that.
Old Jun 21, 2011 | 10:57 AM
skinny z's Avatar
From the feedback I have from a friend who just purchased an ADM hood for his 67 Chevelle, the ADM piece is of better quality than the Goodmark one. He had fitment problems with his Goodmark hood and ditched it in favour of ADM.
If ADM bought out Goodmark, they revised the tooling to provide (what I hear) is a higher quality product.
Old Jun 21, 2011 | 01:01 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I'm running Glasstek hood I bought off eBay. Seller was reselling it because it had 2 broken corners on the front when it arrived to him. It took me a few days to fix it, but turned out nice. I didn't care for the 1/2"+ thick edges as it covered most of the turn signals so I ground that back to about 1/4" and filled it in for a nice flush finish.
I have installed pictures on Facebook, but I can't get to them here from work to post them. I haven't had it painted yet or built an air pan as I'm still working on getting the motor tuned and will be going through some spacers eventually. No sense in building a pan just to find out I need to redo it for a spacer height change.
Old Jun 21, 2011 | 02:52 PM
skinny z's Avatar
This hood on my TA is a little too much for my taste but that's what it took to cover the big block with an RPM Air Gap intake.
I would think half that height would be enough for the 353 and Air Gap.
Old Jun 21, 2011 | 08:37 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
hmm okay. I have goodmark and its damn good.
Old Jun 21, 2011 | 10:01 PM
skinny z's Avatar
Don't get me wrong. I'm not disrespecting your hood. I'm just relaying someone else's experience. What I like about the whole deal is that there's at least an acceptable hood available for a decent price.
Old Jun 21, 2011 | 10:21 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
I know it's not a V8 but... Here is mine.. 4" Harwood to clear the velocity stacks.
This is from inside the car, minus the air filter and the sealing foam..
and an older engine shot.. I don't have a recent one with the foam installed. The air filter side is completely sealed to the back of the hood.
With the foam sealing it to the hood my intake temps are ambient where as before it would get to 120F+ while moving and 150+ while sitting.
Old Jun 21, 2011 | 10:36 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Oh i know you werent disrespecting man. I wasnt tripping mine is an older goodmark when I got it 4 or 5 years ago.
That is an awesome setup im really impressed. it looks damn good
Old Jun 22, 2011 | 01:17 PM
midias's Avatar
[QUOTE=skinny z;4956900]
Mine is ~4 at its highest point
Old Jun 22, 2011 | 02:01 PM
Engine: 383 SBC
Mine's the 4" Glasstek.
Old Jun 23, 2011 | 02:58 PM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
Axle/Gears: 9 bolt, 3.45
3 inch on my girlfriends car-
Big piece of $hit. Got it from a big ebay seller with a lot of positive feedback. The people must have left the feedback before actually installing or painting their hoods, or were too dumb to notice the ****-poor quality. Two full days of body work got it to look like a hood at least. Spending the extra $100-150 on a name brand hood probably would have actually cost less in the end
Old Jun 23, 2011 | 05:49 PM
skinny z's Avatar
.. 4" Harwood...
Hmm..lots of 4" hoods out there.
Old Jun 23, 2011 | 05:52 PM
skinny z's Avatar
Big piece of $hit.
Even the name brands crank out crap (consider where they're made).
I went through several boxes at the supplier picking out a hood for another car and it was tough to find anything that didn't need a makeover.
That's just the way it is.
Old Jun 24, 2011 | 03:19 AM
Engine: LO3
Would anyone be so kind to post the width of the Harwood cowl?
From the pictures Purple82TA posted it appears to be less then 28" wide.
Old Jun 24, 2011 | 11:11 AM
68Strat's Avatar
Car: '83 Sport Coupe
Engine: 360
Transmission: TKO-500
Axle/Gears: 12 bolt 3.73 TrueTrac
Here is my Sunoco
http://www.flickr.com/photos/53106660@N03/5620144687/
Old Jun 24, 2011 | 03:20 PM
GTFiero's Avatar
Car: 86 Z28
Engine: 355
No aftermarket hood fits perfect, but this was awful. Ive had very good results on the overall quality on other installs such as glasstek, cervinis and harwood. When i say this hood was terrible, it was terrible. Its "gel coat" was like chalk, the whole cowl was actually sagged in and needed major reworking, and a ton of air pockets and pin holes filled and much more. I was almost ready to just cut my losses and trash it and buy a harwood.
Old Jun 24, 2011 | 10:31 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
I might go glass at some point and time
Old Jun 26, 2011 | 12:37 AM
Engine: 450HP 355
Transmission: TH350
at the top (back of the cowl) it's 22" wide, at the bottom is a little less than 26 and it's 4.25" tall.
Other than the ugly front lip this Harwood hood is top notch. It's over 10 years old and still looks good.
Old Jun 26, 2011 | 11:33 AM
Car: 91 formula
you not kidding about hood fitting. when i bought my 4 inch harwood. it took my brother and I over an hour to get this hood on and able to close.
Old Jun 26, 2011 | 02:58 PM
Engine: LO3
Ok, thanks a million for measuring.
I´m going to build mine, so I needed a measurement to start with.
Thought it might have been 22".
Not sure however if I build it from sheet metal or carbonfiber though.
Sheet metal can be welded to the spare stock hood I already have, will be tricky to get the edges of the cowl rounded evenly.
Making rounded edges on a carbonfiber cowl is easy, attaching it to the steel hood will be a pain however.
Either which way, doing it right will be a lot of work.
Will then also build an aircleaner element, a little like the one I posted, that will fit in the cowl, so when closing the hood, the cowl area will be sealed around the aircleaner element like in the original cowl inductions from the 70´s
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Aug 20, 2015 03:55 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
