Daytona cowl induction hood / Iroc turbo cowl hood?
Old Jun 23, 2011 | 09:10 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
Hi there, long time reader of these forums and am also on Camaro5.
I recently aquired my dream car back in Jan., a 1987 IROC-Z 5.7L. T-Tops and power everything. it's a work in progress of course, but runs strong.
prior to even getting the car I knew I wanted this hood for it (Primarily for looks): http://i32.photobucket.com/albums/d5...ngSS/hood1.jpg
my dilemma is, however, I have no clue what it's proper name is, I was recently reading tid bits about cowl induction hoods and read the names "Daytona cowl induction hood" as well as "Iroc turbo cowl hood"
3 things I'm curious about:
what's it's accurate name?
where might I acquire it?
and - the holes in the side of it, are they to allow Hot air Out of the engine compartment?
Thanks in advance for any information!
Old Jun 24, 2011 | 12:21 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Re: Daytona cowl induction hood / Iroc turbo cowl hood?
You could order a new one here for instance:
http://www.hawksthirdgenparts.com/ho...omponents.aspx
It is described as Camaro 82-92 IROC Turbo Hood on their site.
In these forums it is often referred to as Daytona turbo hood.
I guess the main reason for that is that there is a, somewhat rarely seen, twin turbo hood for the Camaro as well, so referring to this one as Daytona hood prevents confusion.
The holes on the side are by default closed. They are just indentures when you buy the hood.
Opening them up would provide heat extraction.
With a proper cowl induction setup (air filter box) you´d have an interesting hood on the car, and I do agree these hoods look good on our cars
Old Jun 24, 2011 | 01:53 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
thank you for the information!
Do you know if it is possible to cut and make the holes on the side functional without sacrificing the structural integrity of the hood itself?...
Old Jun 24, 2011 | 03:35 PM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Yes, it is.
Old Jun 24, 2011 | 11:36 PM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
Thanks again!
- if anyone comes across this post and knows someone selling a used Daytona Turbo Hood, please let me know.
Old Jun 25, 2011 | 12:37 AM
MAC_87's Avatar
Car: 1987 IROC-Z
Engine: 5.7L
Question: Hawks Iroc Turbo Hood - if I select "No do not add hood louvers with hardware" will it be delivered to me like the image below, Minus the plastic louvers? - and I could just swap mine in?...or will it be flat on top of the cowl induction?
Old Jun 25, 2011 | 02:15 AM
Engine: 3.8, 3.4
It will look like mine in my sig pic, idk if it uses the same louvers that the factory cars came with though, something you would have to ask the people at hawks.
Old Jun 25, 2011 | 02:24 AM
Engine: LO3
Yes, you can swap the factory louvers in.
Selecting the louvers adds the partnumber for the factory louvers to the order.
Old Jun 25, 2011 | 02:28 AM
TheMonster's Avatar
Car: 1983 Z28
Engine: Forged 355
I ordered mine from hawks. It takes a few weeks to get it an shipping is high, but your buying a hood which isn't a small package. I cut the holes on mine, and put in a mesh where the holes are. There is a space in the hood where you can put the iroc louvers which I assume you have.
Also another thing is it comes with a 1" lip on the front for shipping strength. You can file that off of there for a cleaner look.
Old Jun 25, 2011 | 02:40 AM
Engine: 3.8, 3.4
2nd hand hood ftw :P Mine already had the holes cut, and mesh installed, and one of the POs, probably the original, also had some custom fab work done on it, has these recessed triangles at the front, then I further modified the hood but completely removing the substructure and making it into a true pin on hood. It's not as rigid, but as long as I'm careful with it its still sturdy enough.
Eventually I might get a CF bolt on hood, pin on is nice when you're doing a lot of underhood work, but the rest of the time its an annoying PITA, esp with how large the hoods are on camaros......
Much as I hate to say it though, the odds of finding one 2nd hand aren't good, truthfully I wasn't even looking for this style hood when I found it, was planning to get a factory glass IROC-Z, but then this one cropped up uber cheap.(paid like $70, had some damage though, which I fixed)
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
sailtexas186548
Feb 29, 2016 08:40 AM
mustangman65_79
Aug 11, 2015 03:17 PM
