firebird and camaro floor pans interchange?
Old Jul 4, 2011 | 10:42 AM
Project 3.4 Camaro's Avatar
Car: 1996 Camaro, 1985 Camaro
Engine: 3.8, 3.4
Transmission: WC T5, 700r4
Axle/Gears: 3.23(?), 3.42
Question in the title, yes or no? Trying to find a used floorpan and if I can use a bird one it might open up some more options for me.
(on a budget, and my seat bracket is not salvageable, and for some reason the new repo pans don't include the seat bracket thats welded to the factory pans...)
Old Jul 4, 2011 | 06:37 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: firebird and camaro floor pans interchange?
because the repo pans are just that, pans. the crossover braces that house the seats studs are different parts.
AFAIK, all 3rd gen pans are the same
Old Jul 4, 2011 | 06:46 PM
Engine: 3.8, 3.4
Maybe so, but its not like anyone reproduces them, or at least no one that I know of...and just speaking logically, if someone needs a new floorpan, then there is a quite good chance their seat bracket rusted out too. Mine is so bad there is literally nothing to bolt the front left to, and the front right is on wafer thin rust.
Old Jul 4, 2011 | 06:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
thats why i just shake my head when people say "i have to change the floor pans, how easy will it be?"
nobody thinks about the crossover braces, seatbelt mounts and the subframes.... nto to mention all the other braces, anchor points and other brackets that dont come with the floor pans.
But like i said before, im pretty sure the floor pans are the same in all 3rd gens. 4th gen ones are similar from the driver seats back, but not the same
Old May 31, 2024 | 11:48 AM
Elwoodwrigley's Avatar
so can you interchange a Camaro third gen floor pan - I need driver front for my Formula? Will the braces line up?
Old May 31, 2024 | 01:16 PM
B4CYA's Avatar
Car: 85 Z28/87 IROC-Z/92 B4C
Engine: Twin turbo LS9/SC LS9/L98
Transmission: RPM T56/T56 Magnum/700R4
Axle/Gears: 9"/Dana 44/10 bolt
Firebird and camaro floor pans are the same. But there are some year changes. Later cars have more crumple zones. I used a 91 floor pan in my 85 and there were some folds that werent there on the 85. So I had to improvise. But it worked just fine. My best recommendation is to find a donor floor pan from a similar year car.
Old Jun 1, 2024 | 06:45 AM
Thank you for the information. The hunt is on. It is a 1989 Formula with one soft spot on driver side feet area. If they make a patch panel may go that way as the rest of the floor is solid.
Old Jun 3, 2024 | 11:48 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
New reproduction floor pans are available. Same for Camaro or Firebird. If you don't need an entire floor pan, you can section what you need from the new one.
colton_carlson
Mar 8, 2019 12:21 PM
Linson
Aug 21, 2015 02:12 PM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Amillionoh7
Aug 7, 2015 01:24 PM
