Why it so hard to find The Paint Code Bottom aero dams silver
Old Jun 4, 2024 | 08:16 PM
Extrafitkid's Avatar
Car: 1986 TRANS AM
Engine: LB9
This is a 1989 ( Slobber ) My 1986 is the same color. I'd like the repaint it I can't find the silver code to the bottom of ground effects anywhere. 30 minutes on google? Also, any suggestions on those silver Rims below my are Black I LOVE the silver color better. Thank You for any info you can spare! This is my fantasy end point for my1986. My Interior is Mint even the automatic counsel isn't separated jaw drop.
Old Jun 5, 2024 | 09:10 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Re: Why it so hard to find The Paint Code Bottom aero dams silver
U may end up having a paint store scan the surface for the silver to produce the correct colour paint.
Old Jun 5, 2024 | 09:36 AM
ACebell's Avatar
Car: 1983 Camaro Z28
Engine: Originally LU5, but now Carb'd
Transmission: TH350
Axle/Gears: 323
Conflicting paint codes appeared for searches. But the paint is called Silver Poly. I found the code of WA8536 for 1983. In 1985 the code was WA7448; again, called Silver Poly.
Old Jun 5, 2024 | 02:48 PM
Car: 1986 TRANS AM
Engine: LB9
Thats an Idea Thanks!
Old Jun 5, 2024 | 02:50 PM
Car: 1986 TRANS AM
Engine: LB9
Oh a hit ! Thanks ACebell very much I'll look into them!
Old Jun 5, 2024 | 04:44 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
these are the paint codes for 86 ,your Silver metallic is code 13,you'll have to look up silver metallic 13 on a paint code website to get the color code WA-------
all clues say WA9021 GM Pontiac color code
Old Jun 5, 2024 | 05:02 PM
Car: 1986 TRANS AM
Engine: LB9
Mantaguy You Rock!! Thank you for Checking on it ..
Man, I'd hate to ask but is the 1989 paint code the same 13 silver paint code? (See blue 1989 TA in pic at top)
If you have access great if not, I'm running what you gave!
Old Jun 5, 2024 | 08:51 PM
mantaguy's Avatar
Engine: 5.0 EFI
same code 13 WA9021
Old Jun 6, 2024 | 11:29 AM
Car: 1986 TRANS AM
Engine: LB9
https://i.giphy.com/media/v1.Y2lkPTc...9LZJ/giphy.gif
Click link above! My journey has end you are the Best Mantaguy !
cornerlot
Sep 1, 2017 11:45 AM
cornerlot
Sep 1, 2017 07:28 AM
Crusin' 1980's
May 22, 2006 03:40 PM
phess11
Oct 1, 2004 06:30 AM
FastElectrics
Apr 1, 2004 12:15 PM
