Im wondering if anyone out here has raised their rearend
Old Jul 15, 2011 | 04:56 AM
travisgold's Avatar
Car: 1984 Camaro Z28
Im wondering if you guys have raised your rear ends because i would love too do it but im not sure how to go about doing it. pictures and a guide would be greatly appreciated!
Old Jul 15, 2011 | 05:59 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Im wondering if anyone out here has raised their rearend
Throw in a pair of Moog replacement springs (5665) and/or a pair of fourthgen isolators. Both would put you up to nose bleed height.
JamesC
Old Jul 15, 2011 | 06:18 AM
the solitaire's Avatar
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
Confirmed. Raises the car approx. 1" compared to stock ride height (stock in the 1980's not the current ride height) for the springs alone.
Not sure what the 4th gen spring isolators will do. I want to get back to stock ride height rather then further raise the rear so I have not tried them.
Old Jul 15, 2011 | 06:21 AM
JamesC's Avatar
I was speaking for fourthgen spring isolator/insulators, which will jack the butt up.
JamesC
Old Jul 15, 2011 | 06:26 AM
Engine: LO3
I'm afraid I used the wrong term indeed.
Bumpstops are not isolators.
Will correct that in my previous post
Old Jul 15, 2011 | 06:58 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
a notchback will give you a good 2in raise.
Old Jul 15, 2011 | 07:09 AM
conlinj's Avatar
air shocks for that ultimate 70's lift...
Old Jul 15, 2011 | 07:20 PM
puma1552's Avatar
Why do you want to jack it up? Stock ride height already looks too high.
Old Jul 15, 2011 | 07:38 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Airshocks a bad idea in these cars - the shock mounts in the rear are **** poor thickness to begin with - start using them to hold the car weight, and you'll end up with your shocks in the rear glass where they broke through.
Coil spring spacers that sit on the bottom of the coil spring - easy, cheap, come in a variety of heights from 1/2 in to 3+ inches.
If air adjustability is desired, look into Air Lift drag bags ($90) that fit inside the coil springs and restrict the amount of coil compression - you can add air to reduce compression, and release air to increase compression.
Old Jul 21, 2011 | 09:22 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Fourthgen rubber spring isolators will raise the rear about 1". When I changed out my springs to Eibach's it dropped the car 1" all the way around. I added the isolators to bring the rear back up to stock ride height, but with the stiffer spring. The car has a nice rake now.
Old Jul 21, 2011 | 09:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
2"? not a chance. the notch is not that much lighter than the factory glass. your talking ~400lbs of weight to raise the back 2"...
OP, Like said before, Moog iroc springs, alone will raise the rear some, and the 4th gen isolators apparently raise about 1/2" or more.
Happen to have a pic of the car right now?
Old Jul 22, 2011 | 12:43 AM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
I always thought if you raise the rear end the back of the car will go down...
Old Jul 22, 2011 | 12:45 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I got a good 2in lift id like to lose going to the notch.
Old Jul 22, 2011 | 02:48 AM
Engine: LO3
Moving the battery to the trunk should about even out the weight difference between notchback and glass hatch.
Old Jul 22, 2011 | 03:09 AM
EvilCartman's Avatar
Car: '82 Z28
Don't forget to put on some side pipes and wheels that stick out 2 inches from the rear fender.
Old Jul 22, 2011 | 11:42 AM
IROC#1's Avatar
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
I see your notchback is held down with hood pins. How do you prevent people from just removing the pins and entering the car?
Old Jul 22, 2011 | 02:40 PM
Car: 1989 IROC
Engine: 305TPI
Wow, how did this become a pick on Gumby thread?
Anyway, don't raise the rear of your car. It's a bad idea on many levels. It kills handling, screws up brakes and makes a complete blind spot.
(it's almost as bad as putting on wheel spacers)
Old Jul 22, 2011 | 03:10 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
cause the stock lock is still there and working.
They are there to help hold it down cause stock shocks are so strong they make the corners twist up when shut. They are also out side the weather strip.
see sig link
Old Jul 22, 2011 | 03:44 PM
cIaRmOaCrZo's Avatar
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
hahahahahaha
Old Jul 22, 2011 | 03:53 PM
jimmy_pop15's Avatar
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
You could look into getting shocks custom made. Just contact the manufacturer and tell them the weight of the notchback lid and they'll make you a pair for about the same price as stock ones at the auto parts store. We've had custom ones made before.
Old Jul 22, 2011 | 08:33 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
I have Ballons in the springs still from when I used to run larger wheels. Simple lift the rear to where to want and blow the balloon. Dont use them anymore, just havent gotten around to removal, one has a hole too.
Old Jul 22, 2011 | 10:15 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
I'm not really sure if I want to waste my time by asking but what dose "this" comment have to do with helping to raise the rear of a car . Some of these cars look nice with a slight rake.
Old Jul 23, 2011 | 01:42 AM
Car: '82 Z28
Not really.
Old Jul 23, 2011 | 02:00 AM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Not really.
I agree.
Old Jul 23, 2011 | 06:06 AM
JamesC's Avatar
JamesC
Old Jul 23, 2011 | 12:57 PM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
you can always install bags
Old Jul 24, 2011 | 05:10 PM
travisgold's Avatar
wow leave this thread for a little while and it turns into a blow up.
Old Jul 24, 2011 | 05:16 PM
travisgold's Avatar
anyways the car the way it is, is very low right now i only want to raise the rear end about 1" or a tad more like the one guy said give it that classic 70's muscle car look, and the lift will go good with my high performance v6 i got in it im boring out the engine, 60thousands replacing crankshaft, and camshaft
Old Jul 23, 2012 | 04:15 PM
cz28coptzer327's Avatar
Car: 84 camaro Z28
Transmission: borg warner T5
couldnt you go with air shocks?>.. thats what i have on my 84.. gives it a good rake
Old Jul 23, 2012 | 11:08 PM
WickedCrazy's Avatar
Car: '91 Firebird '85 Firebird
I think you have something wrong with your shocks/springs. I've never seen a rear get effected by taking the rear glass completely off as to go up 2 inches. Let alone replacing it with a notchback. Ive helped install 2 notches and it didn't effect ride height at all.
Old Jul 26, 2012 | 10:17 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
except shocks and springs don't grow when bad and lift a car, they sag / it gets lower.
Old Jul 27, 2012 | 08:11 PM
406ci91rs's Avatar
Car: 1991 camaro rs
Engine: modded 305 v8
Transmission: th350
Axle/Gears: stock rs gears
Originally Posted by JamesC
JamesC
my thoughts exactly
Old Jul 27, 2012 | 08:13 PM
406ci91rs's Avatar
Car: 1991 camaro rs
Transmission: th350
this car looks sick! nicely done!
UltRoadWarrior9
Apr 28, 2020 10:39 PM
BWilcox
Sep 20, 2015 12:19 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
