look what i found
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
look what i found
while looking for my factory wheel lock wrench today i pulled the spare tire and found the bottom of the spare tire area more or less completely GONE. i got under the car and looked and the bottom of the 1/4 on that side is rotted to just under where the gfx bolts to. i would have never found this if i hadnt pulled the spare out or got under the rear to check it out. someone had a trashbag duct taped over the hole. guess ill just go get some sheet metal and cut out what i can and patch it up. may have to cut off the very bottom of the 1/4 though :/.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: look what i found
quite typical rot area. whats the rest of the floor look like?
mostly pretty good im gona do some more digging tomorrow. i cant tear it down too much it just became my new dd for a few weeks. my wife got in an accident and totaled her 2011 civic thursday and she has been driving my yukon since. i was surprosed though cause the car is in excelent shape otherwise just high miles 253k. my 86 trans am is all solid other than where i had to patch a little in the driver pan.
how do most people fix this area just use some sheet metal to remake the bottom? mines eat up into the bottom of the 1/4 too but the gfx hides it.
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
easiest way would be to find a jy car with that peice not rotted out, and cut it out. and then trim and weld it in place of the metal you gotta cut out.
thats what i was thinking of doing if i can find any yards around that still have 3rdgens.
Car: 91 Camaro RS
just remember to always cut out a piece bigger than what you need from the donor car...
Engine: gone
Transmission: gone
Axle/Gears: gone
yeah cutting the metal out of another car is the best way. You can make your own but thier is no way for it to be perfect. But if its fine for you I cannot hate on you for doing that. Its metal, you can take away and put back no biggie.
Abubaca
Nov 5, 2016 12:22 PM
rudolphschenker
Sep 4, 2015 02:41 AM
