How to Prep and Paint Engine Bay??
Old Jul 19, 2011 | 10:04 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Guys,
Could use a little help on how to do it. My plan is to take some 120 grit sand paper to it to scuff it up, wipe it down with paint thinner, put a few coats of primer on it, put 2 or three base coats on, and then clear it.
Do i need to sand it at all between the primer/base/clear? What do you guys do?
Thanks!
Old Sep 4, 2011 | 09:18 AM
morb1lee's Avatar
Re: How to Prep and Paint Engine Bay??
sounds like a ton of work or the engine bay..unless it's a show car. I'd do it to the drips you create or any really rough spots...you can always just try it on one wheel well and if you like it do it to the rest.
Old Sep 4, 2011 | 03:26 PM
BloodBassist's Avatar
Car: 87 Iroc
Engine: 350tpi
Axle/Gears: 10 bolt, unsure of gears yet
Honestly I cheated. I bought some rough scuffy pads, scuffied it all down, wiped it down with some DX320 then Rattle canned it with some semi-gloss black rust oleum. But no, do not sand between Color and clear. As for primer, let it dry, Guide coat it and wet sand with 400 grit. let dry, blow it off, go over it with a dry paper towel to get rid of left over residue then wipe with some sort of cleaner, I personally use PPG DX320. base, tack rag, clear. If you want to take that route.
Old Sep 5, 2011 | 07:23 AM
morb1lee's Avatar
How'd it turn out? I'm looking to upgrade engines in about 2 yrsish...after i buy a house with a shop... and would either a be doing A good chunk of body work or B finding another body thats solid.
Old Sep 6, 2011 | 01:35 AM
Car: 87 Iroc
Engine: 350tpi
My rattle can job? Quite well actually, my only issue is that I got a few runs. I forgot how rustoleum tends to come out of the can so heavy. Honestly most people cant even tell I just spray bombed it. theres a pic in my gallery if you want to see.
Old Sep 6, 2011 | 03:10 AM
Carlos773's Avatar
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
It depends how good you want it. Want it to be flawless like the rest of the car? Then yes do all the steps possible to make it good. If you want a black engine bay meaning a non matching exterior color then life gets very easy since alot of the rust stuff like POR or Chassis saver comes in a good glossy finish that if done right can look very good.
Old Sep 6, 2011 | 04:10 AM
Twin_Turbo's Avatar
POR turns milky rom uv exposion and needs texture to hold, not the best choice
Old Sep 7, 2011 | 08:21 AM
ctoledo0834's Avatar
Car: 87 camaro Z28 convertible
Engine: 350 carb
Transmission: th-700r4
Axle/Gears: Posi traction 3.42 gears
I think I'm going to paint mine. I'm just going to sand the rough spots and use some high temp engine paint
Old Sep 7, 2011 | 09:21 AM
Engine: 350 carb
I have some rust by the battery tray what can I use to fix it before it what the engine bay ?
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
